Holley boost control
Old Jul 24, 2020 | 05:54 PM
Novaray64's Avatar
Default Holley boost control
I'm plumbing in the boost control solenoid, it a holley # 557-201. This is a twin turbo setup with dual port wastegates. I do no want to run CO2 or a pump so was planning to use the compressor outlet as the pressure source. Can I use the dome pressure control method with a psi sensor in top of the wastegate while using the compressor outlet as the pressure source? Or is there a better way to plumb it?
Old Jul 24, 2020 | 09:32 PM
Quito195's Avatar
If it’s not too late I’d return the $300 solenoid and get a 3 or 4 port Mac valve for $40. Matt happel on sloppy has a bunch of good videos on setting up boost control, you can also split the MAP sensor signal to get PSI instead of running a dome sensor. But what you described will totally work as well. Just my .02.
Old Jul 25, 2020 | 05:43 AM
stevieturbo's Avatar
Trying to use dome pressure on boost fed control....doesn't seem correct because that boost will be a large variable.
Just do a regular simple setup as Quito says. Simple mac solenoid or one per gate is all that is needed.
Old Jul 26, 2020 | 07:03 PM
Novaray64's Avatar
I already have the holley solenoid and its mounted. Is the any way to just use the valve I have?
Old Jul 26, 2020 | 09:06 PM
Quito195's Avatar
Exactly how you described should get the job done. Compressor housing are a good pressure source.
Old Jul 27, 2020 | 03:01 PM
Shownomercy's Avatar
Man-Crush Warning
Why not just run your map signal as dome pressure and keep it simple.
Old Jul 27, 2020 | 04:06 PM
Quito195's Avatar
I think people equate the p/n’s in the Holley drop down menu(s) as “simple”. Kind of genius on their part. I agree completely with creating an input off the map and using it. Super simple to split the signal at the ECU and loom it back in....skip all the other non-sense.
OP one thing worth mentioning is that using your MAP as a “dome sensor” is actually way more accurate for target boost. Simply put MAP is your actual boost so it’s all 1:1. using a dome sensor is the amount of boost on top of the gate to reach your target boost which will vary depending on WG priority, spring size etc so there is more variables to hitting your target boost #. Hopefully not terribly confusing. Again, great videos on YT about this stuff.
Old Jul 28, 2020 | 10:19 AM
Novaray64's Avatar
I am definitely confused on all the different ways to setup the boost control. I have everything plumbed in so I don't want to make any changes since its all installed but I could use some help on the setup. I'm using the holley high flow solenoid with the compressor as the as the source pressure. I have the lower port on the wastegate going to the compressor housing and the upper port going to the solenoid outlet. I drilled and tapped the wastegate top for the dome pressure sensor.
Is it better to run a heavier wastegate spring or lighter?
If I wire a switch to disable the boost control in holley will it use the wastgate spring pressure?
Once everything is up and running can I change the boost psi on the fly without hooking up a laptop? I have the 12.3 pro dash and 7" dash
Old Jul 28, 2020 | 05:48 PM
Man-Crush Warning
I would start with a light spring and see how the system responds. If it nets you the boost you want to see then you are good to go, if not, baseline it well, then toss heavy spring in.
I think you may be setting yourself up for confusion with using comp as pressure source, along with basing it off of dome pressure, but thats my opinion.
Old Jul 28, 2020 | 06:25 PM
nocooler's Avatar
Which system are you using? The options are a little different.
Holley and others have very good videos on how to set this up and make it work using various strategies. Jump on YouTube and search. The nice thing about Holley is it’s extremely flexible.
Old Jul 29, 2020 | 06:28 PM
Novaray64's Avatar
Holley dominator, I will check out the videos on it
Thanks
Old Jul 29, 2020 | 06:40 PM
nocooler's Avatar
Dominator and HP offer map or dome control without the need to splice the map signal like some people do with the terminator https://documents.holley.com/199r10628rev2.pdf - straight from Holley
Old Jul 29, 2020 | 08:57 PM
69-chvl's Avatar
I gotta tell you the open-loop/duty cycle based control works pretty dam good. If you want to keep it simple.
Old Jul 30, 2020 | 08:53 AM
blackdak318's Avatar
This is the way my system it set up and I have absolutely zero complaints. It regulates well from about 8 psi up to ??? psi. I've made 22.8# on the dyno on 75% duty cycle. Hopefully within about the next year I'll see what it makes on 100% duty at the track lol.
