Oil Feed NPT Sealant
I'm installing a Precision ball bearing turbo and have a 90 degree fitting going into the oil feed. One side is NPT, the other side is -AN. What should I use on the NPT side that goes into the top of the turbo to prevent leaks? I installed it dry and it leaks when it warms up.
I've read teflon tape can melt, I don't know if that is true, I haven't seen it but thought I'd ask to be sure.
Thanks
