How far have you gone on pump gas? Boost wise
How much power you guys making at such high psi? My car does 30ish HP per psi with twins. My buddies making 500 at 9psi with a single. Both on stage 2 cams with 5.3. I could t imagine running 16psi on either car on pump gas. Hell my tuner has me running M1 on the 14 I’m in now.
I"d drop 2* and grab some cheap br7 plugs. Then do a full pull. Can't really read an old plug. And at $8+ a plug tuning by the plugs will get pricey quick! Looks way to hot to me as well, but as said hard to tell.
Why no water/meth? Costs peanuts to put DIY kit on a car. 7gph-10gph of straight washer fluid pulls a lot of heat! Hell you can rig the windshield washer sprayer up pre turbo and it will help quite a bit. FWIW that's about the same timing and boost I run on e50 with water/meth. (no intercooler) It gives my 8 heat range plugs a nice safe heat range on the ground strap.
The following users liked this post:
Kfxguy (08-03-2020)
17psi but it was on 90 and I could only get like 3-4* of timing on it. I ran it like that last for the 2 weeks it took to ship my WMI controller back and get it replaced(it bricked). I can get 20psi at 8* with the meth. You can run a ton of boost if you pull all the timing. But on the track it did better with 14psi and 12* than it did with 17psi and 4* when I had no meth injection.
It was like a 13sec truck with 14psi and 12*, I ran it 11.2sec with 19psi and 8* and a cracked hotside pipe. It's about 4300lbs, long bed c10. I got a Cortex boost controller last week so I'm eager to get back and try again with some actual traction control via boost control. Was running a $15 bleeder valve before.
I have a nozzle preturbo right now. Tried it a couple times, felt like it gave it a little bit of a nudge (felt smoother is how I can describe it) but of course I didnt see an IAT reduction. I thought I would, but i Only see 2 degrees. Guess thats better than rising? maybe I just need to start using it till I have the time to do the whole system i was planning.
you'll really like the cortex once you get that dialed. It has two output channels that have several options for activation. The boost by gear works flawless. I can control mine down to 5psi in first gear and up to 19-20 in 3rd. Without this controller, my car would be uncontrollable.
IAT's aren't important IMO. You'll get bogus readings with lots of volume anyway. Getting the water in the cylinder where it can pull heat is what matters. I literally "felt" no difference. My e85 intercooled rx7 runs the same times at 22lbs with the 10gph of on/off. Can't even feel it come one. That's what you want IMO. But if you look at the plug, it's noticeably cooler with the water/meth (washer fluid) on. Not to say other gains aren't to be had with a better kit and more volume, higher meth % etc. Just saying for a cheap simple on/off kit at low volumes... you get a cooler cylinder with it. Not so much a performance mod as safety mod. Unless you up the boost of course.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#33
IAT's aren't important IMO. You'll get bogus readings with lots of volume anyway. Getting the water in the cylinder where it can pull heat is what matters. I literally "felt" no difference. My e85 intercooled rx7 runs the same times at 22lbs with the 10gph of on/off. Can't even feel it come one. That's what you want IMO. But if you look at the plug, it's noticeably cooler with the water/meth (washer fluid) on. Not to say other gains aren't to be had with a better kit and more volume, higher meth % etc. Just saying for a cheap simple on/off kit at low volumes... you get a cooler cylinder with it. Not so much a performance mod as safety mod. Unless you up the boost of course. ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
gotcha.
#34
#35
Aight. I’m still figuring out this boost controller. I was trying to use closed loop but something wasn’t jiving so it was fluctuating the boost in third gear and I could always feel it being held back. That was a major killer right there. I turned closed loop off and just used open loop. So I get 18psi in second gear and 19 in third with a surge of 20.1 on the 2-3 shift. So I ran a couple logs just now.
afr 10.8
duty cycle 71.2% at 6800 in second 223.9kpa
timing is 12.9* at that point
rpm drops to 5359 on the 2-3, from a 6800rpm shift. Timing drops to 7.5 at the shift.
Then tapers back up to 12* by 5500
coolant temp at the end of the run was 181f
iat was 131f. Higher than I thought. So yea, I’m hooking up the washer pump this week to spray pre turbo till I get a chance to do it correctly. That should give a little extra safety cushion.
i took 1/2 degree timing out. Pulled 2 degrees more in the 2-3 shift. Smoothed our my fuel map. I lied earlier by accident. My afr was closer to 10.5, so I took a touch away to get it to 10.8.
afr 10.8
#40
I wouldn't... You can get the same nozzle for $5. Their pumps are nice, but also not necessary for a single on low volume setup IMO. Simple $20 water pump a few pushlock nylon fittings and line and a 5$ nozzles is really all thats needed IMO.
http://www.greatplainsupply.com/en/nozzles/110-outside-mount-nozzles-do1.html
The pressure switches there are the same Devils own stocks as well. But I've had them fail. I've never had a hobbs brand pressure switch fail. I'd go that route personally.
