spool time s480
Old Jan 17, 2021 | 07:34 PM
  #81
blackdak318's Avatar
That timing table is a literal joke. I seriously hope you didn't pay a "tooner" for that. Yikes. Also way down on power IMO. I don't see the wastegate being recirc into the exhaust being an issue at all.
Old Jan 17, 2021 | 07:54 PM
  #82
lscamaro234's Avatar
What do you guys suppose a
5.3
Btr stage2
S475 1.1 83mm turbine
#16psi e85
Should make at the flywheel?
Old Jan 17, 2021 | 08:25 PM
  #83
ddnspider's Avatar
700 minimum.
Old Jan 17, 2021 | 08:38 PM
  #84
No tracks running here but that would be about right. My last setup here was 615flywheel 450atthe tires.
And my mates ls combo here was 800flywheel and 600 at the tires with the mph matching.
I see a lot of you guys seem to make only about 50hp loss at the tires when using an mph weight Calc??
Any of that make sense
Old Jan 17, 2021 | 09:02 PM
  #85
AwesomeAuto's Avatar
5.3
Btr stage2
#16psi e85
I did over 700 at the wheels with a 5.3, smaller 218/218 cam, Billet S475/87 1.10 T4, 17 PSI, 93 pump gas.
No reason with more cam and better fuel you shouldn't be right there.
Old Jan 18, 2021 | 10:47 AM
  #86
rt338b's Avatar
My timing table I posted was a 5.3 with a summit stg2 cam and 475 on E40 that was 750 Wheel so what he has going is way down on power considering mine was soft on 16lbs.
Old Jan 19, 2021 | 08:16 AM
  #87
M33P's Avatar
How much timing in this setup? I am doing a s475 with a sum stg 2 on 93 pump and am curious. lq4 with a th400
Old Jan 19, 2021 | 09:24 AM
  #88
Forcefed86's Avatar
5.3
Btr stage2
#16psi e85
Double the NA hp. Pretty straight forward. Stg 2 5.3 should make 350+
Old Jan 19, 2021 | 09:44 AM
  #89
12 degrees from 16 PSI and up.
