A/R selection and WG selection
som trans am
416lsx 6bolt motor 9.5to1
Glide 1.80
Precision x275 85mm with 103 wheel
3300 lbs
holley dominator efi
Options for a/r are 1.40 or 1.25
I was thinking twin 50mm bov
And a single 66mm precision gate
Any info is appreciated and why you choose that. added a few pics just for the fun haha
Wastegate needs to be big enough to control boost, but small enough to not cause issues with crack pressure.
A large gate that is CO2 controlled is gets both benefits.
Go with the larger housing. The only reason to go smaller is for improved response at the cost of more back pressure. You shouldn't have trouble getting that turbo into boost on the brake with that motor. No reason to go with the smaller housing IMO.
Precision has the 66mm gate i believe?
what brands do you recommend?
I wanted to stick with precision but if you have good recs I will absolutely listen.
Thanks again guys
