How about some Turbo numbers?
Old Nov 27, 2020 | 09:41 AM
JimTA's Avatar
Default How about some Turbo numbers?
I am searching for my next turbo and there is spotty info all over so thought I would ask and see if we can collect some numbers in 1 thread..
Tell us what you can so the next person can make some informed decisions....
-Motor size
-Relevant mods
-Turbo specs
-HP or Track times or both
Old Nov 27, 2020 | 11:10 AM
red fury's Avatar
347ci (factory LS1 with rods n pistons)
MAST 215cc heads, LS2 intake, M6
On3 7876 t4 .96 ar
839whp / 836wtq std correction, E85 on 16 psi
Tuned by PatG
Old Nov 27, 2020 | 12:48 PM
Kfxguy's Avatar
On3 7876 t4 .96 ar
Tuned by PatG
Thats quite impressive numbers for a 7875. I didnt think they would make more than 750rwhp....makes me really wonder what my billet 7875 is making at 22psi on a heads/cam 5.3.
Old Nov 27, 2020 | 01:51 PM
stevieturbo's Avatar
or search...there's like thousands of answers and no doubt dozens or threads.
Old Nov 27, 2020 | 02:22 PM
JimTA's Avatar
Exactly my point dozens of threads with the data all over. Thought it might be nice to consolidate a little.
Old Nov 27, 2020 | 02:23 PM
So did all the others starting a similar thread.
Old Nov 27, 2020 | 02:35 PM
JimTA's Avatar
thanks for the input... don't want to post numbers fine but please don't clog up this post too
Old Nov 28, 2020 | 09:08 AM
blackdak318's Avatar
- Dart LSNext 388"
- Tick Stage 2 LS3 Turbo cam (small for this set up). Brian Caskey ported LSX-LS3 heads. China Sheet Metal Intake.
- Forced Inductions S491/102 T6 1.32
- 1008 RWHP 23 PSI 18.5 degrees E85. Unlocked 4L80E and Mustang Dyno.
Should have a lot left in it. I think this turbo has another 10 psi to give at minimum. We stopped because the data log showed momentary drops in fuel pressure but was maintaining AFR. Long story short it was dropping battery voltage into the 11's and turns out that is bad with 3 electric fuel pumps lol. Fixed that issue now though with XS power alternator and 14V battery. Fuel pumps like 16.8V now! Been 6.02 @ 119 with a 1.39 60' a year ago on about 16 psi total and soft down low. Adding a legit cage and some chassis parts this winter and plan on getting after it big time this spring. Hope to go easy 5.50's. Edit: This is in a fox mustang btw not an F body.
