Best budget A2A intercooler ?
https://www.treadstoneperformance.co...1000hp/p104562
another good comparison.
https://ls1tech.com/forums/forced-in...ific-test.html
This is from Bells site. I am sure build quality has some impact but seems one has to decide how much they want to spend per hp, just like any other mod.
Does one style core cool better than another?
No, almost no difference. With three decades of testing intercooler’s, we have found no appreciable difference between any core style or manufacturer. Keep in mind, that the merit of a core is it’s efficiency versus its internal drag characteristics. When sized for a tolerable flow loss, virtually all cores will produce essentially the same efficiency results. Perhaps a core with slightly less flow area per linear inch, or one with longer tubes, will need perhaps 5% more tubes to equal the best of intercooler’s with regard to flow loss and efficiency. Not a very important difference. I'm in no way saying IC's are a bad idea. Just that if you run one, you might as well spend the extra money for the "mid grade" TS over the Ebay unit IMO.
Some china cores are a HUGE restriction while doing little for charge temps. I don't agree that a non octane limited setup will be faster w/o an IC. Even with the octane, youll always make more power w a GOOD IC. As a good ic will see less than a lb of pressure drop and can cool more than enough to overcome that small pressure drop. Esp. A2W units.
How is it not proof? Blowers are fixed displacement. If a crap ic is robbing you 4lbs of boost (even tho it cooled the air charge a bit) It wasnt enough of an improvement to overcome the large loss in boost. And when the IC was removed and the boost jumped 4lbs, it made enough power to overcome the higher charge temps.
Same thing happens w a turbo. Only it can make up for the pressure differential across the core somewhat. So its not noticed as much unless the unit is tapped or has issues spooling. It some cases it will still have to make 15-18lbs before the engine sees 10. So response is crap. Then the turbo makes more heat because it has to run more boost to compensate. It also taps out sooner. So w a crap core u get crap response, makes less power per pound of boost, and taps out early.
Weigh a TS unit compared to an ebay unit. The cores are much denser... they simply work better. Anyone who has switched out the like sized ebay cores has been amazed at the difference it makes.
