Best budget A2A intercooler ?
This unit is still on sale. Tough to beat at $342 shipped.
https://www.treadstoneperformance.co...-968hp/p104564
It doesn't do a ton for detonation resistance on pump gas, but anything helps there.
The extra HP is the main reason to run one though. We were seeing 120+ HP gains over no intercooler on a 1200 HP setup when using an A2W on the engine dyno with the reservoir filled with methanol and dry ice.
We didn't do it because it was practical. I wanted to see just how much power could be gained going from ~250+ IATs to ones below 0*.
A 10% gain is a lot considering the intercooler was probably undersized for what we were doing.
I wouldn't doubt another 40-60 HP on a proper intercooler/pump compared to what we were using.
Nice part is quick turnaround too, no swapping water, ice or waiting for a big heat sink to cool down, returns to ambient almost immediately.
Does that ~100whp include a timing pull or just back to back IAT change on same timing?
Was the power adder tapped out at 1200hp?
I ran E50 and no intercooler on a GTX55 94mm and twin 7875’s so basically endless boost on tap with either setup. Seems to perform on par with E85 without taxing fuel system as much and get better MPG.
No intercooler is just fun, great response, and it confuses the majority of people. When you get sub 3000lbs the weight seems to be worth more than the meager power gains.
It looks like I'm already spoiled from the Flex Fuel out of the pump...It's up to $2.49/gallon now around me, and I actually was a little pissed when I noticed that...especially since Top Tier "super" unleaded at Costco is $2.29/gallon.
My car actually seems to like the diluted E (60-70% from using more 93 unleaded) better than 80-85%
