Best budget A2A intercooler ?
However if you can shave off a fair bit of the price for roughly comparable performance utilizing a Treadstone intercooler vs the Procharger, I'm all ears. At this rate, I'm thinking I may just say **** it and get the Procharger setup and be done with it, but I'm also in no huge rush and can take the time to plan this out accordingly.
Can you elaborate more on your reasoning?
Some china cores are a HUGE restriction while doing little for charge temps. I don't agree that a non octane limited setup will be faster w/o an IC. Even with the octane, youll always make more power w a GOOD IC. As a good ic will see less than a lb of pressure drop and can cool more than enough to overcome that small pressure drop. Esp. A2W units.
How is it not proof? Blowers are fixed displacement. If a crap ic is robbing you 4lbs of boost (even tho it cooled the air charge a bit) It wasnt enough of an improvement to overcome the large loss in boost. And when the IC was removed and the boost jumped 4lbs, it made enough power to overcome the higher charge temps.
Same thing happens w a turbo. Only it can make up for the pressure differential across the core somewhat. So its not noticed as much unless the unit is tapped or has issues spooling. It some cases it will still have to make 15-18lbs before the engine sees 10. So response is crap. Then the turbo makes more heat because it has to run more boost to compensate. It also taps out sooner. So w a crap core u get crap response, makes less power per pound of boost, and taps out early.
Weigh a TS unit compared to an ebay unit. The cores are much denser... they simply work better. Anyone who has switched out the like sized ebay cores has been amazed at the difference it makes.
Yes, of course I'm talking about 40% discounts as the OP is asking what IC he should buy with a limited budget. IMO. Why wouldn't I tell him he can get better IC's at 40% off right now?! You can get the 1245 1000HP IC for $260! Why the hell would you buy a crap Ebay IC for $150 when you can get one that performs much better for $260? $260 is a drop in the bucket and a GREAT price on that IC. Its literally the best price on a decent performing IC out there. Which is what the OP is asking about. You're not making any sense. It's like you're trying to justify the fact that you run an ebay IC and it works. That's not being debated. Lots of things work. If you swapped out to the $260 IC you'd pick up power and improve response for very little cost difference.
The debate is a poor IC VS mid level decent IC. Not a pump gas car with no IC VS poor IC. The point is the pressure drop across the ebay cores can be garbage. I've literally seen 8 psi drop across the $130 core (and heard of more) which IMO is total junk. Not to mention it didn't cool as well. Measure yours, let us know what you find. Until you have experience swapping the ebay core out with a TS unit and can give some data points... everything is just opinion. I've been there... so have many others. Ask then their opinion after making the swap. I've yet to talk to someone who doesn't think it was worthwhile.
Lol, I'm not cherry picking anything. The blower example is directly related and helps easily explain why a crap IC can hurt more than help in SOME cases. It removes the WG from the picture illustrates the point more clearly. A WG doesn't' "fix" the problem. It only makes it less noticeable with a turbo setup. The turbo is working harder with less response to do maintain "X" manifold pressure. It's the same as dropping the pulley size on the blower to get the desired manifold pressure, it will do the same thing the WG is doing.
Who cares if their turbo setup works worth a damn? Really? How about anyone with a clue? Why in the world do you want your turbo making 28lbs (or more) to get 20 in the manifold? Then cooling the charge poorly to boot? When for what.. another $110? you can get an IC that will actually be efficient? Not to mention improve the response at ton, get on the TB/2-step sooner etc.
A lot of builders stress out about a FMIC. They go through a lot of trouble to fit them and block their radiators, cut up their cars. Then the install a unit that works poorly at best, and in SOME cases can do more harm than good because thats what they heard worked. When for a a little more money you can put something decent in the car that performs MUCH better. Again... not a theory, a fact.
I'm clearly not "well off" in anyway. I build my stuff about as shoestring as it gets budget wise... Even I'd spend the extra $100-200 to put a decent IC in my car. And I'd suggest any new builder do the same. Its the purpose of this forum. Feel free to disagree, I'm in no way offended by someone disagreeing with me. I'm just stating my opinion and the facts that lead me to that opinion.
You know, REAL street car activities.
You know, REAL street car activities.I dont get what AC has to do with IAT’s if your turbo has a fresh air feed as my IAT’s weren't any higher when I had AC. Guess it helps I have an electric water pump and my engine bay isnt churning 220* coolant temps like most people. I have to beat on my car to even get it over 160*.
I think people just over think IAT like they do so many other things.
I’ve seen guys driving around LSA setups with 200+ IAT’s that the intercooler pump died on and they didnt even notice, still did burnouts from stoplights and moved a heavy car along just fine.
I dont even run E85, its not needed on your average street setup. I run E50 at best since I get better MPG, street car after all.
As far as packing goes doesn't get any easier than routing cold side without an intercooler.
I dont know who doesnt have access to any ethanol, west coast and Maine I guess. Ive been able to find it easily all over the east coast, south and mid west.
But I can get pretty much same results with 93 and meth. I ran too small a turbo over ten years ago with no intercooler. Sometimes just ran washer fluid if thats all that was available. Not optimal by any means but was enough to walk most anything I ran up on during the commute.
I’m not saying running no IC is a perfect setup by any means, especially on setups that have to be run well outside their efficiency zone. But it seems to work well enough especially in street cars with meager power levels. Most people aren’t going to notice a difference between 712 and 737 horsepower cruising to cars and coffee spinning their rain tread street tires.
