Turbo filter
Old Dec 17, 2020 | 06:43 PM
Rscaamaro's Avatar
Default Turbo filter
Does it make much difference in iat having the turbo intake shielded in engine compartment on single turbo street car. Whats the ideal size and type of filter I should be using on a 4in inlet diameter turbo
Old Dec 17, 2020 | 07:00 PM
Shownomercy's Avatar
Man-Crush Warning
As big a filter you can fit is the best
Old Dec 28, 2020 | 12:00 PM
Forcefed86's Avatar
Size isn't everything! lol
R2C Black air filters are the best I've seen. Super popular with the diesel crowds.
They flow 480-495 CFM per sq./ft. at .5" WG
Compared to K&N media that flows 68-72 CFM per sq./ft. at .5" WG
So thats like 6-7x what an K&N does in a like size filter.... Pretty substantial.
http://www.r2cperformance.com/black-...l-filters.aspx
Old Dec 28, 2020 | 02:08 PM
Jimbo1367's Avatar
Forceded86,
that’s impressive. Thanks for sharing
Old Dec 28, 2020 | 02:13 PM
Kfxguy's Avatar
I'm in the camp that believes the cooler the air going into the turbo is less work the intercooler has to do. Maybe I should test my theory.
Old Dec 28, 2020 | 03:26 PM
Man-Crush Warning
True
This is mine, S&B oiled, 12 in x 5.25in. Not sure what the S&B filter material flows.
Old Dec 28, 2020 | 03:52 PM
Forcefed86's Avatar
S&B are great! lots of size choices and great website. Ran one of those for years before switching to the R2C. (believe it was a dry filter) Also FWIW I saw no difference in performance at around 900 crank power levels switching to the R2C. Think it was only a 6.5" filter as well, feeding an S480.
Old Dec 28, 2020 | 06:05 PM
2JZFC's Avatar
I've always used AFE and wonder how they compare. Also wonder why R2C doesn't offer a reverse cone. That would add a substantial amount of filter area.
Old Jan 3, 2021 | 06:15 PM
stevieturbo's Avatar
These are mine....sucks having zero room lol.
Although surprisingly pressure drop inside the filters is a lot lower than I'd have ever expected. So not worried.
https://burgertuning.com/products/bm...4fcb7a3f&_ss=r
Always fit as big as you can though, and always good quality
Old Jan 3, 2021 | 10:34 PM
rotary1307cc's Avatar
They do offer the inverted cone
I have depression data on both the the black hex and aFe dry flow in the real world
Old Jan 4, 2021 | 01:31 AM
3 window's Avatar
I made a ram air type scoop that seals off the filter from engine heat and only allows air to enter from the grill area. It’s not a perfect cylinder, it tapers as it goes toward the turbo.
I also run the aFe filter. HUGE pita to make a cone shape with a flange that tapers 2/3 of the way around but is flat across the “top” as in my case.
Old Jan 4, 2021 | 05:34 AM
Placing obstacles close to the filter will do nothing to aid flow, give as much room around it as possible.
Old Jan 4, 2021 | 08:52 AM
Here is the new black hex pictured, larger than the AFE.
​​​​​​Good bit up over 1k hp, you can see the MAF... Just under 140lb/min in the lower pane
​​​​​​Depression showed in lower pane aswell
~5kpa, so less than 1 psi there still even
Old Jan 4, 2021 | 08:55 AM
And here is the smaller, dirty old AFE vs the black hex at 1000hp
100lb/hr. Overlaid
black hex Just a little bit better but if the AFE was fresh I'm not sure
Old Jan 4, 2021 | 09:28 AM
Even my tiny little filters were only showing around 50kpa drop. Which for their size, I was more than happy with, and quite surprised.
Old Jan 4, 2021 | 10:08 AM
2JZFC's Avatar
Zac, great feedback! Seems to me at the 750-800rwhp level, it would be a wash between those two and it comes down to price and finding a size/shape that fits.
Old Jan 4, 2021 | 10:17 AM
No problem, data is ftw lol
Eeither one would be great and honestly the AFE would be right there If it was fresh, Even though it's about a wash right now
I used that AFE in a high dust environment on my compound turbo diesel.... It is crinkled because I had dropped kicked it across the shop lol
I had very fine dust on the inlet tube getting past the filter, So a paper filter went back on
But on a streetcar out of very fine gravel dust it's fine lol
Old Jan 4, 2021 | 10:21 AM
You can configure the AFe filter how you want btw. Check out their website and making a custom filter
Old Jan 4, 2021 | 11:03 AM
ddnspider's Avatar
Where are you guys buying the R2C's from? It looks like you have to go through a distributor and can't just click and buy online?
Old Jan 4, 2021 | 05:50 PM
Black_Sunshine_99's Avatar
I went to Summits website but the measurements for them are really confusing, way to many numbers for my dumbass lol.
By Brett Foote | 2026-06-04 05:00:17
