Brackets for TBSS + LSA
Old Jan 19, 2021 | 04:26 AM
Fang's Avatar
Default Brackets for TBSS + LSA
Does anyone know of a Alt/PS bracket kit, for LSA clearance, that works with the Trailblazer/Envoy's goofy *** one-of-a-kind power steering pump?
If not (I haven't been able to find one in my own searching), what's involved in swapping to a regular truck PS pump to use the readily available truck bracket kits? The Trailblazer hose config & connection point is completely different... does it require a custom pressure hose? Or can the regular truck hose be made to fit? I have no idea what the differences are at the other end of the hose, or overall length.
Old Jan 27, 2021 | 09:54 AM
Fang's Avatar
Everybody hates Trailblazers? And/or, LSA blowers are DUM! 'cause they won't make 1000HP?
Old Jan 27, 2021 | 12:45 PM
007FJ's Avatar
Start with looking at the PCM of NC LSA kit or you could buy my Magnusun 2300 TBSS Cathedral kit that isn't for sale but could be since I haven't put it on the Aero yet. I also have all of the part numbers from the LSA TBSS kit somewhere in my phone from going that way almost the first time. Actually owned the LSA to TBSS kit before I decided to go with the other one.
Old Jan 27, 2021 | 01:01 PM
Fang's Avatar
Thanks. I don't see any LSA kits at PCMofNC, maybe I'm just missing something.
What started me down this rabbit hole was seeing the BTR truck LSA kit, then remembered the goofy power steering thing. I don't know why GM used a different pump on the Trailblazer when the truck pump/brackets had been in production for so long - I dunno if it's a fluid supply thing, or a chassis clearance thing.
A LSA bracket designed for the Trailblazer pump looks like it would be really awkward - to get the alternator far enough out of the way for the blower, the PS pump would have to be waaaay out to the side for the weird reservoir to clear the alternator. I don't know if all that would clear the frame/etc.
Old Jan 27, 2021 | 01:26 PM
007FJ's Avatar
https://www.pcmofnc.com/product/2010...ilblazer-ss-3/
That's how they do it.
Old Jan 27, 2021 | 02:14 PM
Fang's Avatar
Oh... well, what's that Yogi Berra quote? "For people who like that kind of thing, that's exactly the kind of thing they'll like," or something along those lines.
I finally figured out why the TB didn't use the normal truck pump: it's that stupid front diff mounted to the side of the oil pan on the 4WD/AWD models. Trucks used a conventional frame-mounted front diff. Since I'm 2WD I can use the regular truck accessories, and then the regular truck LSA bracket kits. Still would like to hear from anyone who's done the swap, as there are several different truck pumps for different RPOs. Also unclear on what PS pressure line to use.
