Loss of oil pressure when boosted
Old Mar 29, 2021 | 01:59 PM
hawkhuys's Avatar
Lightbulb Loss of oil pressure when boosted
Running a 6.0 LS Pro Charged with 20 psi boost, oil pressure runs at 70 psi until it's boosted, as soon as we apply boost the oil pressure starts dropping and ends at 50 psi with 20 psi boost. As soon as soon as the by-pass valve opens the oil pressure goes back to normal at 70 psi, testing was done on a wheel dyno making 1000 hp at the wheels.
Engine is completely re-build from top to bottom and previously broke in with 2 hours of run time. Removed filler cap and opened both vents from valve covers with very little change, very slight vapors escaping.
Where can this pressure be going and why is it related to boost?
Old Mar 29, 2021 | 05:57 PM
Black_Sunshine_99's Avatar
Are you using an electric or mechanical gauge?
Old Mar 29, 2021 | 06:41 PM
hawkhuys's Avatar
Digital read out LCD screen
Old Mar 29, 2021 | 08:17 PM
jordoza's Avatar
Install a mechanical gauge to verify the reading. I'd say you have an electrical issue not mechanical issue.
Old Mar 30, 2021 | 04:50 AM
Jimbo1367's Avatar
Couldnt it just be because you are loading the turbos? Does the oil level ever change?
Old Mar 30, 2021 | 07:09 AM
klinznilk's Avatar
States: Running a 6.0 LS Pro Charged with 20 psi boost
there are no turbos
Old Mar 30, 2021 | 07:27 AM
69lsxbody's Avatar
Are you running a high volume oil pump? If so, is it possible that you are having a oil starvation issue as boost/engine speed increases?
Old Mar 30, 2021 | 09:37 AM
THIS, I've had more than one electric gauge give me funky readings that were debunked with a mechanical gauge.
Old Mar 30, 2021 | 09:41 AM
RonSSNova's Avatar
What is the overall system voltage doing during a run? Do you have that data in the log?
