Turbo AR Effect on Drive Pressure
https://youtu.be/7ulC-0A1fzE
Worse in 5th or 6th if cruising at 60-70mph.
With a stick I would have to drop a gear if I wanted to move quickly.
Haven't driven my TH400 car enough yet to gauge but from the little bit I've driven it, it seems to build boost much faster.
Pulls on the street started at 40mph in 2nd gear, 3rd had noticeable lag.
My cam was a bit oversized for the combination so that may have been a small contributing factor.
It was intended for a 6.0L+ engine with a big single but its what my buddy had laying around so we used it, the chop at idle was beautiful.
M6 car w /3.73 gears and 26' tire
3rd gear @ 40mph is 3500 rpm
4th gear @ 40mph is 1950 rpm
5th gear @ 60mph is 2300 rpm
6th gear @ 70 mph is 2150 rpm
Yes , it would be expected to be laggy at those rpms except for 3rd gear where Boost is already starting at a good point.
Boost was still pretty low in 3rd at 40mph and while I could start a race there, it still left me trailing by half a car on the hit, 2nd fared much much better.
This was also on gate before I added an EBC, the car came up on boost much more violently after the addition of the EBC and unfortunately I sold the car shortly after but I'm sure it would've made a significant inprovement.
These are the rotor and pad kits, front & rear. Didn't realize LT1 and LS1 had different brakes.
If you go directly to PowerStop site, you can also "add" calipers to the kit. I have stock rear calipers, and reman'd fronts, painted them (and the caliper brackets) a metallic dark charcoal gray, which gave the look I was after, with my Billet Specialties wheels.
I actually lucked out when I bought mine, as there was a "Clearance Sale" at Rock Auto. They can be had at most places for $300 or so...
LS1 Rear Brakes:
Power Stop K1548-26 Front and Rear Z26 Carbon Fiber Brake Pads with Drilled & Slotted Brake Rotors Kit
LT1 Rear Brakes:
