Compressor Map VS Real world
Currently running a 370" 9.0-1 compression ported ls3 heads, VS Racing 69/73 billet .91ar twins, LJMS TT stage 3 cam, 3800 stall converter, 3.70 rear gear, 3500lbs, E85. Car is about 50% drag 50% street. Just want to make a responsive 1000whp, with the ability to support a 408ci at 1200whp.
The car is pretty laggy on the street, and at the track takes about the end of first gear to hit wastegate pressure, I can build about 6-7 pounds footbraking with 2 step at 3800. Next step is transbrake....
Doing some research and using a match bot, reading compressor maps, puts me right on the money for using a 69/73 as far as efficiency. But I see guys running 6266s or smaller on 400+ cubic inches making 1300+whp.
Are Borg warner just lazy or would it benefit me to go to a better brand like precision or a Jose FI built turbo? Would a 66/68 be a better spooling option? Biggest question I want it to obviously be worth it and a noticeable change.
Why did you build a 9.0:1 engine if you wanted it to be responsive? SBE unit would be more responsive and hold 1000.
Have you tried anything else besides the VS to have something to compare it to ? Honestly I don't and that's why I'm asking.
I've had multiple Precision, Borg, FI (borg and garrett based), Garrett, etc in addition to a myriad of knockoffs.
