How do you guys cool your engine with intercooler covering radiator
With the stock 4th gen radiator, I was running the stock puller fans, but put in front of the radiator and wired to push. Did a great job cooling but the fans howled in the backward direction since the blades were not optimized in their shape for that direction. The Griffin radiator is cooled (still pushing) with two of the Derale Fans. I used this writeup for my radiator and fans. Griffin Radiator.
- big griffin rad , single pass , and not the extra thick one
- Taurus 3.8 L fan
- 160 stat with 1 hole drilled 5/32 IIRC
- remote derale trans cooler with fan ( 0 trans heat added to engine cooling)
- as much air directed through rad as possible , air dam under rad support and rad to rad support reasonably sealed
got the ac heat exchanger stuffed between the IC and the rad now too.
i target 210* coolant temp and it has no issue holding it.
My current car has a pretty large Be Cool universal rad, no IC'er, only thing in front is a small trans cooler. I have one 16" Spal puller, which covers about 60% of the rad., at idle it will pull down the temps at idle. But it doesn't seem to cool like I thought it would, but I run a Holley term X max, and when the engine is cool, the temp sensor reads cooler than it should. So I dont know if I am getting a true temp after warm up. But its what the ECU bases the fan on with. I have installed 180 thermo., but its always higher.
A known problem w/ the Holley supplied sensor.
No need to not know.
Change the sensor, and then tune the fan temps.
- Taurus 3.8 L fan
My current car has a pretty large Be Cool universal rad, no IC'er, only thing in front is a small trans cooler. I have one 16" Spal puller, which covers about 60% of the rad., at idle it will pull down the temps at idle. But it doesn't seem to cool like I thought it would, but I run a Holley term X max, and when the engine is cool, the temp sensor reads cooler than it should. So I don't know if I am getting a true temp after warm up. But its what the ECU bases the fan on with. I have installed 180 thermo., but its always higher.
Some guys on bookface were just talking about how much timing they run at idle and cruising, and for the latter some guys talked about how their cars run cool with big timing, like 35-40 degrees. Some guys commented they run as much as 22 degrees of idle timing. Then you have other factors like some guys running turbo setups in tight engine compartments and there is nowhere for the hot air to go....
I hope this helps.
Paul
