E85 timing
Old Nov 8, 2021 | 12:20 PM
  #81
rt338b's Avatar
[QUOTE=yenkomike;20391615]That is a good running car for sure. Same goldbox setup as yours. Need to compare notes with one another sometime.
Old Nov 8, 2021 | 02:11 PM
  #82
3 window's Avatar
What’s that fallback on the shift Mike?
Old Nov 8, 2021 | 02:18 PM
  #83
yenkomike's Avatar
I’ll check my log as soon as I get home about 6 pm.
Old Nov 8, 2021 | 06:24 PM
  #84
yenkomike's Avatar
Shifted the last run at 6690 rpm dropped to 5770 rpm . Just under 6100 rpm and the stripes. 3.42 gear 275 pro. Converter is a ptc. 9.5. 17-0 stator. Rpm never dropped below 5650 once it was at 18 psi boost. Car is most likely 3500+ with me in it.
Old Nov 8, 2021 | 07:01 PM
  #85
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
what intake manifold on it?
Old Nov 8, 2021 | 07:02 PM
  #86
yenkomike's Avatar
. Factory ls2
Old Nov 8, 2021 | 07:55 PM
  #87
LS1Tech Co-Founder
Would it pick up shifting a little higher?
