Rod bolts and main studs
Old Sep 26, 2021 | 07:56 PM
vht's Avatar
vht
Default Rod bolts and main studs
I was talking to a guy that does my machine work today and he said main studs, ARP, and rod bolts are mandatory when using Gen 4 rods and pistons in a boosted application. I'm putting Gen 4 rods and pistons in a 2004 5.3 block. I'm taking the rotating assy to be balanced so while everything is up there I want to get everything done. What do you all think? This is a budget deal but I plan on making some decent power. If I end up over 20 lbs of boost what should I be replacing? I'm going to build a better short block later, planning on using the Summit Racing rods and pistons because it seems like they've been getting good reviews.
Old Sep 26, 2021 | 08:05 PM
LLLosingit's Avatar
To me there is no need for main studs and probably no need for rod bolts unless you plan on making 800+ and then I would go with forged rods and pistons at minimum.
Old Sep 26, 2021 | 09:07 PM
vht's Avatar
vht
That was kind of my thought on main studs, the LS engines are pretty healthy there but I thought I'd ask and be safe. Do you all reuse the main bolt or install new since they are torque to yield bolt?
Old Sep 26, 2021 | 09:19 PM
eff10mm's Avatar
Mains are torque to angle, not torque to yield. Big difference in that. Main bolts are totally reusable.
Old Sep 27, 2021 | 06:46 PM
vht's Avatar
vht
Thats what I meant, just wasn't thinking right.
Old Sep 29, 2021 | 08:06 PM
epfatboy's Avatar
I just asked a few of these Q's
https://ls1tech.com/forums/forced-in...stons-arp.html
I detailed what I plan on in the thread but in summary I'm gonna run OEM Rod and Main bolts (will purchase new) on my right around 800WHP 4.8 build.
Old Sep 30, 2021 | 03:17 AM
jayyyw's Avatar
I made 1050whp with stock main bolts and rod bolts on my SBE gen 4 5.3. Spun it to 8000rpm every time I drove it. Motor was used and abused long before I got it as well.
