Turbo 427 ls suggestions
For compression I’d go for 8 up to 9 SCR. Personally I’d go maybe even lower. 7.5 may even be reasonable if you really want to crank the boost up on the top end. Keep in mind that with any centrifugal supercharger, including turbos, it’s going to produce next to nothing on the bottom end. So getting off the line may suffer, a little. Also keep in mind though that this may actually be beneficial for traction and require less hardware, but still make gobs of power up top.
I’m not really a fan of the argument that low SCR is a bad idea because of off the line power. Most engines spool pretty damn fast, so losing a few tenths of a second of acceleration to your max boost isn’t much of an argument to me when you can add in power on the top because of the low SCR.
Lots of success stories out there though involve between 8-9 SCR, but like I said, physics are simple in this. Best bet is as low as possible with as much boost as possible. This keeps the fuel safe and makes tons of power.
For the turbo, it will depend entirely on your SCR selection. If you go low, the go big on the turbo. You can even do a sequential setup if you have room to boost the boost lol. That kills the lag, and in that case I’d doubt you’d feel sluggish off the line, even with SCR in the 7’s.
For the turbo, it will depend entirely on your SCR selecti on. If you go low, the go big on the turbo. You can even do a sequential setup if you have room to boost the boost lol. That kills the lag, and in that case I’d doubt you’d feel sluggish off the line, even with SCR in the 7’s.
https://m.youtube.com/watch?v=ZpBrrc...ature=youtu.be
And a turbo setup is NOTHING like a centrifugal supercharger.
I’d add in the huge thing on the turbo is nothing slows it down like a belt driven one, meaning overboost into off throttle transitions are definitely different. The need for blowoff is definitely more relevant and noticeable. Basically, there is lag on all transitions for turbos.
I think the coolest part between either of them is adjustable boost. Someday when I grow up I’ll have enough money to afford a good setup with these features lol. Damn bills are getting in the way of that.
And to the OP, I don’t know if you mentioned fuel or not, but the SCR’s I mentioned are aimed at 93 pump. You can DEFINITELY go higher if you are running something like pure alcohol, or E85, etc. These fuels can take A LOT more compression and boost. I don’t know if that’s your plan, but I think from your goals pump seems to be what you’re aiming for.
I never said PD blowers were adjustable. But Procharger does have a centri blower that is:
https://www.procharger.com/procharge...1_supercharger
BOV's are obviously needed on centri as well. Didn't say they weren't. But I've had a few scares running twins where the boost hung and it got pretty lean, and hot. It is self correcting I guess, I just prefer the safety of a BOV in that setup. I guess you could say it was indeed hard on the turbos. On the centris, only played with a few, didn't see hangs like that though. I'm not the world expert here, just speaking from a few personal examples and my opinion on it.
What? Overboost into off throttle transitions? And technically if you didn't want to run a blowoff valve on a turbo setup you don't need one although it's going to take it's toll on the turbo itself, but try doing that on a procharger and you will blow **** apart.
Adjustable boost on a procharger or PD blower? No. And using a BOV as a pseudo wastegate to regulate boost just doesn't work efficiency nor does it work well on a procharger setup, been there and done that.
I said this same thing recently that turbos need load and another member on this forum said I didn't know what I was talking about.
No explanation, facts or reasoning presented when I pressed, just BS.
Theory and practice seem to be quite different in the world of FI I've noticed.
Yes, they are different. Yes a turbo requires load to do this. I am not disputing that they operate differently. No ****, they obviously are very different. But on the physics level, when talking strictly airflow, they are both centrifugal in how boost is created. They create different curves, but both are similar from the centrifugal/turbo when contrasted with PD. They both produce curves. PD doesn’t, since PSI is mostly fixed, but it does vary slightly. Also, PD blowers don’t use centrifugal force. They trap air on the output side, so it’s not thrown down a tube like centrifugal and turbos do, which both use centrifugal force to do so, and then use Bernoulli’s principle to pressurize the air.
Yep, totally tracking they both produce completely different results, and operate differently. They’re absolutely different. Yes. How the air actually gets pressurized, or moved, not so different. I think of a centrifugal blower as basically being a belt fed turbo. That’s basically what it is.
So your supposed pearl of wisdom is turbo lag exists, amazing, who knew.
Not wasting anymore time with someone who's contribution is "turbo lag is real".
