Help me with my Meth issue
Old Nov 3, 2021 | 08:29 PM
rpturbo's Avatar
Originally Posted by dlandsvZ28
You have a PM.
Thank you sir!👍
Old Nov 4, 2021 | 09:27 AM
Hank Peabody's Avatar
Originally Posted by gsteele
According to the heat of vaporization tables I have seen in the past it is over twice as much heat that water absorbs.
True but the problem is most of the water doesn't vaporize in the relatively cool charge air and it finds one or two cylinders that are easiest to get into and floods them with tiny droplets. Methanol might not pull as much heat out but it vaporizes ALOT easier.
You can't take a swamp cooler and crank up the water it is spraying in the air or you'll just wind up soaking wet. Same with an engine, you might spray a 1000cc nozzle of 50/50 into the air but most of the water doesn't vaporize.
Its easy to test on the dyno or on the track or even the street. The GN guys figured it out a long time ago.
Im really not trying to argue...Ive had a lot of problems with spraying too much water in the past and thought it was valve springs, pushrods flexing, plug gap, etc, and as soon as replacing the water with more methanol it was fixed.
Old Nov 4, 2021 | 09:11 PM
rpturbo's Avatar
So after listening to everyone, I'm curious where everyone is located, and how much the humidity in the atmosphere, would affect the amount of % of spray. Has any of you guys sprayed say 50/50 on one pass vs 100% meth the next?
Old Nov 5, 2021 | 09:52 PM
tblentrprz's Avatar
If your not vaporizing the water, your spraying too much. It's simple as that.
Old Nov 6, 2021 | 03:57 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
The OP has fallen into a newby trap that we are all familiar with. ONLY CHANGE 1 THING AT A TIME. Nail down the tune off meth, then dial it in with the meth. Don't chase your tail trying to do everything at once. When you get the initial tune dialed in, it will be much easier to see what to do with an added meth kit.
Old Nov 6, 2021 | 01:19 PM
rpturbo's Avatar
How exactly do you dial in a tune up top, when it is going to require meth to not get hot?I am far from trying to do everything all at once, I am mearly trying to educate myself on this particular system before I even start to tune a car without a intercooler.
Old Nov 6, 2021 | 01:30 PM
ddnspider's Avatar
I run a mix of water/meth. It's called windshield washer fluid 😂. Works great, no bog with a simple boost switch to trigger it. But starting at 3 psi is too low, especially on a centrifugal car. Set the threshold to something like 7 or 8 psi and I bet the bog goes away if you're tune is close. Also tuning for 10.5 AFR PLUS the water/meth is asking for a big. Too much fuel/liquid. Since you don't have an FMIC, your only choice is to lean out the AFR without the meth and let it bring your AFr back to the target.
Old Nov 6, 2021 | 01:51 PM
LetsTurboSomething's Avatar
They tune a car up to the point it starts needing the spray and make sure it runs really good in all areas at those boost levels. Then they start turning boost up and spray at the same time from there and tune that area of the map.
But ya you can't tune high boost without the spray if it requires the spray to get there in the first place. You can only pull so much timing until you lose max RPMs from it. A lot of people are just running "insurance water/meth injection" and in those cases they would tune the whole map without it. I run at about 27psi and I most certainly have to tune it all with the spray on. It can never really run without it unless you count just not giving more than 10% throttle.
Old Nov 7, 2021 | 01:38 AM
gametech's Avatar
You tune it the same as every other tune. the only difference is that you know in advance that you will have to fatten it up and kill timing. You want to know these things for when your meth injection fails. Once you dial in these limits, you know what to fall back to if a squirrel chews through your meth pump wiring.
Old Nov 7, 2021 | 07:07 AM
fastlt1's Avatar
I sprayed mine before the mat sensor. So if it quit working for any reason and Temps started raising. The mat table would adjust for it.
