wastegates and intercooler
Old Dec 9, 2021 | 06:58 PM
jester1's Avatar
Default wastegates and intercooler
So went through more pages than I can remember but that just sent me in confusion state. Need to decide on gates and intercooler.
Was recommended a pair of Hypergate 45s and compgate 40's but I'm considering china gates. How lucky are you guys getting with them?
As far as intercoolers the Treadstone TR1245R has my eye so far but how about any others that you guys have used? No real data on the summit ones that I have found.
Anyone care to set me straight, maybe add suggestions or advice?
Old Dec 9, 2021 | 07:27 PM
Quito195's Avatar
My friends and I have built probably 10 different combinations with VS gates and BOV’s no issues to date. My personal rig is a single 50mm WG on a 408” motor with a T6 s480. Works great.
Old Dec 9, 2021 | 07:38 PM
jester1's Avatar
They all work out of the box or did you have to do anything? I'm on a s480 also, divided though.
Old Dec 9, 2021 | 10:04 PM
91 Z28's Avatar
I've got the VS 50mm gate and I just had to clean up a bit of metal shavings on the diaphragm and I also lapped the valve with some heavy lapping compound to have a better seal on the fire ring. Other than that was alright. For what it costs I'm not complaining
Old Dec 10, 2021 | 08:54 AM
SLOW SEDAN's Avatar
I use the amazon 50mm gates, same as VSR but without the writing on it. They were $50 but went up a bit to $67. Boost has absolutely been on a rope the last 5 setups I've used them on.
Amazon Amazon
I've used more treadstone TR1245's than I can count, on everything from Audis to Corvettes, solid units.
Old Dec 11, 2021 | 10:42 AM
jester1's Avatar
Thanks for your imput. I left everything for the last minute. Brandon didnt help matters either
Have you used 1245 and the R, if so did you notice any difference?
Old Dec 13, 2021 | 09:30 AM
rel3rd's Avatar
I "had" a single 44mm wastegate, and the On3 chinese 3" intercooler.
Swapped on a 1245R Treadstone and IAT's were/are cooler and 1st trip to dragstrip, the single, (poorly placed) wastegate would no longer control boost whatsoever.
Ended up installing 2 brand new VSR 44's, with awesome exhaust priority, and can now make from 4 to 22#, steady and consistently, using a 4 port MAC valve and my EBoost Street boost controller
Old Dec 13, 2021 | 05:40 PM
jester1's Avatar
thanks, seen your post in the above thread. No stock on the treadstone so Ill wait on that. I think Ill give them a try.
I wonder why the 50mm are cheaper?
Old Dec 13, 2021 | 05:57 PM
rel3rd's Avatar
Maybe a Black Friday sale or something?
Old Dec 16, 2021 | 06:13 PM
Quito195's Avatar
I've never done anything besides take it apart and make sure it wasn't full of garbage. I've definitely seen pictures on the internet of people having issues. I personally have not though.
Old Dec 21, 2021 | 08:55 AM
Black_Sunshine_99's Avatar
Honestly there's no reason not to do this regardless of the brand, the fact is people make mistakes and a few minutes of inspection can save a lot of time and headache down the road.
