Anyone use BTR LS9 head gaskets?
Old Dec 27, 2021 | 04:56 PM
Jimbo1367's Avatar
Default Anyone use BTR LS9 head gaskets?
Anyone ever use BTR LS9 head gaskets? If so, what brand are they?
thanks,
jimbo
Old Dec 28, 2021 | 08:43 AM
DBRODS's Avatar
Yes all the time, they are exactly the same as GM LS9s
Old Dec 28, 2021 | 10:03 AM
Jimbo1367's Avatar
Ok. Good to know. They are cheaper.
thanks,
jimbo
Old Dec 28, 2021 | 03:56 PM
rpturbo's Avatar
The small bore gaskets he has listed, states they are manufactured by the same company that makes the GM LS9 gaskets, so there is probably some pricing leverage there.
Old Dec 28, 2021 | 06:26 PM
Jimbo1367's Avatar
Thanks. I didn’t even see any small bore options. I wanted a set for a LY6/LSA
Old Dec 28, 2021 | 08:10 PM
RedXray's Avatar
I use them on my LQ9 with PRC 225 heads and a 150 shot. No issues and yes very good price!
Old Dec 29, 2021 | 07:21 AM
SAPPER's Avatar
BTR is able to source them directly from the manufacturer so that eliminates the GM middle man.
Old Dec 29, 2021 | 10:14 AM
Jimbo1367's Avatar
Thanks for the reply guys. When you guys gap rings (boost) how far down in the cylinder do you guys typo go? Thanks
Old Dec 29, 2021 | 10:10 PM
rpturbo's Avatar
They cylinder bore should be the same all the way down. You can check them with the ring, and a feeler gauge if you want to go that far. I typically go the depth of the top of the skirt.
Old Dec 30, 2021 | 03:23 PM
Jimbo1367's Avatar
Ok Sounds good to me.
thanks !
jim
Old Dec 31, 2021 | 03:33 PM
sr71's Avatar
I put the oil rings on a piston and use it to square them in the bore.
Old Jan 2, 2022 | 09:25 AM
RonSSNova's Avatar
Ditto
Old Jan 2, 2022 | 11:55 AM
Jimbo1367's Avatar
Thanks guys. For boost, should I do anything for the oil ring? What is the standard or rule of thumb for gaping? I’m sure with only 30k miles they’ll be tight.
Thanks,
jimbo
