6.0 stroker build.
There are a lot of advantages both in performance and longevity by having a sturdy cylinder wall that is the proper length.
I've read many times about guys with 408 strokers having piston rocking issues, premature wear and ring seal problems and these are compounded when boosted or sprayed.
You could look at a 6.2 block for about $2,400, TMS does a Darton sleeved block using your own block also for about $2,400.
Not easy to spend that kind of coin on a block but I think the investment initially will be well worth it when you hit it with a big shot of giggle juice down the road.
But now that still leaves the cylinder sleeve issue though right because you aren't using a power adder and it sounds like you wouldn't recommend it either?
How many cubes is your 6.0L with that 4.25" stroke crank?
On the 6.0L iron block, I think the cylinder wall gets too thin over 4.030” for significant power adders. They seem to want to crack between the bores when you get into the 4 digit horsepower range. Going even further to 4.060” or 4.065” would be fine for NA or maybe a teeny little bit of boost and a babysoft tune, but I would not spray it.
