5.3l 7876 1st dyno
https://vm.tiktok.com/TTPdh475PC/
Thanks. Yea it's on 93 pump. Th400 trans. I did confirm cam timing. Stock rod bolts scare me..wish I'd have went just to aftermaket rod honestly. It didn't fall off at 6400 just kinda flattened. And yes. It's a .95ar I thought it may be my limit. Maybe I'll do an upgrade there. It's fun as hell ATM though. Curious what it'll run now. As far as placement of wastegate. It's a Huron non AC kit. Supposed to be better placement. Thanks again.
like i said, i'm happy with it. i degree'd the cam and everything on build. i'm thinking it's just that i got the smaller exhaust side and that's whats doing it. it's making good power and i'm sure it'll be able to do more. the dyno/tuner even lol'd when i said i'd used stock rod bolts.. he didnt' even have much faith in them. this is my first "high hp" build so. Trending Topics
Cammed 5.3, call it 450 crank hp
15 psi is double atmosphere, so we'll say 12/15 is .80
450 x .80 = 360
450 + 360 = 810
810 divided by .80 = 648rwhp (.80 is drivetrain loss, unlocked converter).
450 x .80 = 360
450 + 360 = 810
Now I know some tuners who would run more timing at that boost level.
A/A intercooler?
What is your exhaust setup? When you made 12 lbs was that with C02 or just off spring?
now I have a 5.3 and I’m on alot more boost. But I did swap out the housing for a 1.25 ar housing. It’s makes more power now at every boost level and has more power out of boost. The lag added was not much.
My advice to you is like I said above, fatten it up and add a small shot of washer fluid. A 5gph nozzle from McMaster carr, pre turbo, using your washer pump, will help carry you a few psi higher
It was pretty flat. I have air to air. Intake temps were 90 at end of pull. I only have a manual boost controller.
.3 x 648 = 19.44 = 628.56 rwhp.
Other guys suggesting adding fuel, I don't see that increasing power for you but you could go for it. But adding some timing would add some noticeable power. If you dyno again, you could throw in fresh plugs and make a pull and see where the timing mark is on the strap. All the sharp guys tell me we should be tuning off plugs.
Richard Holdener just had a vid on U Tube, 3 diff boosted combos, and showed how they reacted to timing. Was def interesting how much power he picked up as timing increased, up to a safe level.
Few years back I ran a guy who dynoed 200HP more than my car made, I beat him, lol.
Awesome. My car is about 3750 me in it. I didn't change timing. Should have to see what it'd do but had limited time and was ok with this being my start point. Waiting for winter gets done so can see wth it'll run.
450 x .80 = 360
450 + 360 = 810
Maybe some of you guys could share what plug readings you like to see, mark at the curve etc. I'd get a few sets of them if you were to go back to the dyno, and read the plugs.
