Tbss & boost
Old Apr 19, 2022 | 11:08 PM
Kurtknarr's Avatar
Default Tbss & boost
I have two questions I will be putting the p1sc procharger on my airboat real soon will my trail blazer ss handle 10 pounds of boost and also will I need to install a blowoff vavle for this procharger? I’ve done some searching but I’m not the best with search engines
Old Apr 19, 2022 | 11:53 PM
theunderlord's Avatar
yes, composite intake manifolds are good to go on boost, and yes, BOV info here
Old Apr 20, 2022 | 11:43 AM
007FJ's Avatar
LS6 on mine has seen 22 and rarely has seen less than 15. I’d think 10 is nothing on any of them.
Old Apr 20, 2022 | 12:11 PM
ALL ULL C's Avatar
I assume since you mention a BOV that you are also looking to put a centri-style charger on the TBSS. You should have zero issue as long as you have an adequate fuel system and octane to support. May also consider some valve train upgrades (springs/rocker arm bushings) if you have not done so and depending on mileage. The last I knew House of Boost was the only company making a dedicated kit for the SS.
Old Apr 20, 2022 | 12:43 PM
Kurtknarr's Avatar
yes sir springs rockers the whole vavle train is done I’m also running flat tops with vavle relief and h beam rods whole forged rotating assembly the bottom end is built
Old Apr 22, 2022 | 05:16 PM
customblackbird's Avatar
15psi on a stock GM NNBS (TBSS) intake and no issues for like 4 years now. Stock plastic are good for quite a bit of boost. It’s the 2 part plastics that have issues like Dorman, fast (I haven’t heard of any fast failures) but anytime you have a removable 2 part design with a seal you can have a failure. Stock GM are sonic welded and not removable so no failure point.
Old Apr 22, 2022 | 05:35 PM
LilJayV10's Avatar
The engine will let go before that intake will.
Old Apr 22, 2022 | 10:45 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I would normally say you would have a significant advantage with a boat engine, because of an endless supple of cold water to cool your air charge. In the case of an airboat, I question this, as they are commonly used in areas where a water intake would be easily clogged by any variety of swampy stuff. Have you thought about your intercooling situation? As for the BOV, it would not be strictly necessary, but is almost always a good idea.
Old Apr 23, 2022 | 07:06 AM
Kurtknarr's Avatar
yes sir I’m definitely going to have to do an a2a intercooler I spend more time running dry then I do in the water
Old Apr 26, 2022 | 11:26 AM
TrendSetter's Avatar
Hardest part about cooling on an airboat is getting the air bubbles out. other than that you have a 60-whatever inch fan moving all the air you could possibly need. no sense in messing with trying to pull water externally.
