Which TVS2300 kit?
How are you guys putting 2300's on these year trucks?
I'm going to be using a LQ4 and can use the cathedral to rectangle port adapters or find some rectangle port heads.
I would like to keep the truck accessory spacing and truck water pump so I am not sure if the jackshaft Camaro version of the TVS2300 01-23-60-173-BL will be the best choice.
I was looking at 01-23-60-025-BL kit designed for the 2015-2019 2500 6.0 trucks but wanted to ask before I ordered something that won't work.
Another one of my concerns is I have been out of the loop as to when and what applications they started using direct injection and would prefer to order a kit with injectors I can use.
If anyone would have a kit for the TVS2300 they would as they have a direct connection to Magnuson (many of the guys there used to work for Magnuson). Their website is always out of date so you'd be better off calling them.
That said, Magnuson has discontinued a lot of the kits, like the kits for the GTO, starting with 2022 so you may be out of luck.
See link: https://superchargersonline.com/prod...-manifold-tub/
Or you can switch over to a Whipple and find them fairly easy.
Tim
I recently purchased this combination direct from Magnuson.
You can also order it from superchargers online like previously mentioned.
Is there something I'm missing here? I would love to know if this has been tried by someone else. It's a little pricey, but if I can avoid the adapters, well worth it.
