Zl1 brick collapsed
I’ve got a question about the Zl1 brick out of a lsa intercooler. When I bought the blower and lid used the brick was collapsed and I inflated it, or popped out, the collapsed section on the back side and welded in a plate to reinforce it. Since then I have also added a 8gpm methanol nozzle on the intake tube before the throttle body to aid in the cooling. The blower has a ported snout and 2.5 upper and 9.1 lower making around 12psi on my l92 engine.
I’m wondering if it’s possible that the brick could still be collapsed internally as I’m seeing iat at around 160 after the 1/4 l mile and cruising air temps of 25-30* above ambient.
My cooling system has a huge heat exchanger made my rd performance in the front, ewp150 pump, and a 3 gallon under hood tank all 12an fittings and hose. I seem to have good flow threw the system as I have a good return stream into the tank.
thanks
I only have personal experience with one, and unless we run ice in it, that's typically what I see.
I thought about buying one of those billet manifolds to get rid of the stock one but didn’t feel it necessary. I couldn’t really find any info backing up the cost.
Also had another TVS on a Vette that would run 12-15 over ambient at cruise with the standard Bosch pump and heat exchanger. Both of these would go up about 35 degrees over whatever the temp was at the start of the run. That was at 9-10 psi.
I think your intercooler needs work.
ive put the system under a vacuum of 15in mercury for a couple hours and it held it. I was thinking maybe it had a air pocket somewhere. But I’ll dive into it again and see what’s going on.
I've never made a full 1/4 mile pass but even after several 3rd gear pulls (manual Trans) It doesn't gain but 10 or 15 degrees.
I definitely think you have something amiss or air in the system.
