Fuel System Upgrade Needed?
I'm running very large cable to the back where the battery is, all the grounds look good and are also large cable like 0 gauge or maybe even 1-0.
With the UDP/truck alt do you still see 13.5-14v at high rpm in the 7,000-7,500 rpm range?
My last car had the same combo of UDP and truck alt but I never spun it that high but it always seemed to be fine.
also. Cost of everything was the only downside.
I don't think I need to go as far as the XS battery yet, there wasn't a problem really until I installed the 3" alt pulley to keep the alt charging at high rpm, I think its simply spinning too slowly at lower rpm.
I looked at my logs and it completely shuts off at idle but kicks back on around 1,300-1,400 rpm where it carries 13.0-13.5v but then drops to 12.7 around 7,000rpm so I think it works just not the way I need it to, with factory pulley on it would probably be fine at lower rpm but then be overspun up top for sure.
You still get full output at high rpm with the factory pulley as well?
Perhaps the DR44 is different?
Stock pulley 145 amp unit ( 8292 with the 4 pin regulator ) will push 110 amps at 14.4 volts with stock 525 RPM idle speed.
I have one on a cammed 4.8 Liter with an oversize 3.2" pulley, and it makes 90 amps at 740 rpm idle speed.
If you are not maintaining 14 plus volts at ALL ENGINE SPEEDS, than something is wrong, either belt slip, or the brushes are bouncing or worn down in the alternator.
AGain: Yukon/ Suburban with both Heated seats, defroster and heaters both on HiGH, and all headlights on, stock 145 amp alternator WILL maintain 14 volts at dead low idle.
While some may be able to get away with it, I'm not usually that lucky and I don't want to buy a new DR44 and install an underdrive pulley only to have it not put out enough juice at idle and be back where I started or run it and over spin it and damage it.
I'm just gonna pick up one of the 250 amp JS units, then I know what I'm getting and that I'll have plenty of power to cover all my needs.
The JS unit put out 14 volts from idle to 9,000rpm and 250 amps up high where I need it without under sized pulleys.
Its really a good deal when you figure a new DR44 is $200 and the pulley is almost $100 too and the JS unit comes in at $329.00.
Went ahead got the 320-amp version for a few bucks more since I plan on adding an oil cooler and WMI injection in the near future and I want to be able to run everything without worry should the situation arrive however unlikely.
The alternator bracket I'm using is made by Goat Built which is a nice bracket but with the additional depth of the JS unit, it was hitting the valve cover so it's not exactly a direct fit although a stock truck alternator would be.
Luckily ICT Billet makes a nifty little extension bracket that moves the alternator up just enough to clear everything.
Then I just had to cut, re-clock and epoxy the oil fill tube to clear the alternator.
I will say it's really nice to see a rock solid 14.1 volts at idle with two coolant fans, trans cooler fan, water pump and A2W pump all running and the idle doesn't even flinch, the car actually idles better too, crisper and stronger.
Can't wait to log voltage at 7,500rpm, wondering if my fueling will change due to the added voltage at the pumps.
Thanks again for the recommendation @jayyyw
I've been logging voltage with the new alternator off the body control module in HP Tuners and its showing 13.2-13.5 volts at 7,500 rpm once warmed up.
At cold idle I have 14.5 volts but once it seems to enter closed loop it drops down a bit.
I know it's not the alternator so I'm wondering it where I'm logging voltage is off or incorrect.
I'm still using the factory 99 ECM which raises and lowers voltage as required so should I worry about this?
Should I just run a separate wire to the alt to command full power all the time?
I also upgraded the fuel feed line to a -08AN and 40-micron filter but I also just picked up a 10-micron element since that's what a lot of people suggest running with fuel injection.
The smaller micron element shouldn't affect fueling right?
