Rear mounted turbo advices needed
Old Sep 20, 2022 | 07:26 PM
  #41
Sebambam's Avatar
Depends on what gear you hit it in. Anything outside of first rolling into it and it's online. If you want all the boost in by then see about the 7665. But if you want to rev much over 6k it'll run out of steam.
thanks. T76 .96ar?
I might look into that since i dont go above 6k+ really.
I also have a pretty torque cam with a good low/mid range rpm PowerBar ( ls summit truckcam)
Which might be even able to make up for low/mid rpm power until the 78/75 comes in
Old Sep 20, 2022 | 08:03 PM
  #42
ddnspider's Avatar
I think you can get the 7665 in a .81 AR. Not sure about a .96.
