Finally sharing my build…
Installed the rear wing and put the parachute back on.
Was gonna fire it up the other day, but had no compression. Did a leak down and nada…. After some investigation, determined my pushrods are too long and were holding the valves open. I’ve measured for pushrods on at least 10+ engine builds and haven’t been wrong yet…I guess I just ***’d up… New ones will be here tomorrow.
Got fuel pressure… but got fuel leaks too. Pinched an injector o ring… thought I had a box of spares, but can’t find it…. I’ll pick some up tomorrow.
In December of 2016, I started this project with a 1999 coupe. First thing I did was convert it to an FRC.
25.5 cage/4-link/9”
RPM TH400/ProTorque Billet U9 converter
Current starter engine - Iron truck block/370”
TFS 245 heads
FIS Ultra Street class S476
BTR custom cam
On Methanol, no radiator, no inter cooler
Holley Dominator
built on jack stands in my garage. Hoping to fire it up this weekend.
2616 with 53% on the nose.
I forgot I had a regular battery in it, and not my Braille, so likely about 30lbs lighter…
I’m pretty happy as I was hoping to be under 2700lbs so I could add weight where I need it to make class weight.
