Finally sharing my build…
Old Apr 1, 2026 | 05:48 PM
  #221
C5_Pete's Avatar
Thanks David.
I got the turbo from BTR. Some sort of a knock off I presume.
We pulled the plugs and could barely see any timing mark on the straps.
I’m planning to race in the 8.50 index class and maybe some Lil’ Gangsters if we get an event near me. So, no need to be on kill.
I will certainly make a few hero passes at some point.
Old Apr 2, 2026 | 08:38 AM
  #222
Black_Sunshine_99's Avatar
Definitely loafing at 1,100whp with that back pressure and timing.
Hopefully you'll get to enjoy the car now for little bit in the 8.50 classes and Lil Gangsters looks like a great class and seems to be getting bigger at every event.
Old Apr 2, 2026 | 10:35 AM
  #223
brutalzo6's Avatar
Originally Posted by C5_Pete
Thanks!
27psi boost
25psi back pressure
14* timing
64% injector dc
Bosch 210 injectors
mechanical fuel pump with 55psi base pressure.
Is this the same as when you ran your 8.21@173? What’s your race weight?
Old Apr 2, 2026 | 11:06 AM
  #224
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I think Pete is non-intercooled?
Old Apr 2, 2026 | 11:25 AM
  #225
C5_Pete's Avatar
The 8.21 was with an FIS 91/102 S400 frame. Also at 13.5:1 CR.
after the accident, is when I rebuilt with the GT55 frame turbo. Also, new pistons to make it 9.5:1CR.
race weight has not changed… 2800lbs
Correct. No intercooler.
