Almost hit 600RWHP
Old Jul 23, 2004 | 09:40 PM
Moz's Avatar
Moz
Default Almost hit 600RWHP
Had my car dyno tuned today. Im running 8 1/2 #'s of boost on a D-1SC with 42lb injectors and a Walbro 340 in-tank pump. The injectors maxed out at 6100RPM. Thats when the air/fuel ratio started stepping towards the 12.8 mark.
586RWHP
534RWTQ
The RWHP was still climbing. So i will be installing an fuel pressure regulator and take the RPM to 6700 and then maybe i can hit the 600RWHP .
Old Jul 23, 2004 | 09:57 PM
MECHAM's Avatar
nice
i think you mean fuel pressure regulator 1:1
Old Jul 24, 2004 | 06:56 AM
Moz's Avatar
Moz
Yes, i fixed my post. I did mean Fuel pressure regulator.
Old Jul 24, 2004 | 12:00 PM
Daily T/A's Avatar
What size pulleys do you run? Is it on the stock bottom end?
Andy
Old Jul 24, 2004 | 12:46 PM
Wet 1's Avatar
I don't know, if you ran out of fuel that early do you think a FPR will get you to 6700 safely? Sounds like it's time to go with some larger injectors.
Old Jul 24, 2004 | 02:15 PM
MelloYellow's Avatar
Try a Boost-A-Pump and/or wire the fuel pump direct to 14v.
Old Jul 24, 2004 | 03:54 PM
1dirtyZ's Avatar
get bigger injectors!
you're really pushing these 42's right now.
Old Jul 25, 2004 | 03:40 AM
LSs1Power's Avatar
Those are really good numbers.... With those 6.0 heads u can go 10psi with no problems. Im sure u can hit over 600rwhp. I thought the 42lbs were enough for 600rwhp?
Old Jul 25, 2004 | 07:40 PM
1dirtyZ's Avatar
they will make 600 hp but you will be well beyond 100 % duty cycle.
