Cooling effects of E85 vs non-E 100-116 octane
At least this is what I see with most of the older generation at the local track especially long-time bracket racers.
I'm guessing it's too taxing on their fuel system and possibly creates higher backpressure at higher revs due to all the extra exhaust volume (if turbocharged).
Interested to hear what they say.
I know things here and there about fuels, but honestly you should just reach out to guys like Jason Rueckert at VP Fuels and folks like that to get the info from them.
Now you'd still have detonation resistance with race gas but your IAT's would probably get high enough to cause concern.
I'd rather have lower IAT temps than not but that's just me.
https://vpracingfuels.com/contact-us/#general-inquiries
I reached out to Jon Capizzi and he shared his experience.
- E85, E90, Ignite Red are his preferred. Ethanol has a wider tuning window. He referred to Ignite as awesome.
- Not a big fan of E98, harder to light off and harder to nail the cold idle.
- C16, has tuned a number of combos like that. Issue is as a fuel it's rough on O2 sensors and the tuning has to be pretty close. "Adding 5% fuel can sometimes cost you over 100hp." His view is that C16 or Q16 can make sense for high compression combos, engine combos with tight quench or tricky combos."
I'll have to go over John's audio clip again but I think you summed it up well.
To conclude my original question, I now fully see the safety in E85 from the cooling aspect, that is what I will go with for sustained runs (1/4 mile stretches) on SBE setups. I'm sure others will have this dilemma and benefit from John's info.
I tune smaller time setups but can appreciate the detonation resistance 40+ % ethanol content offers, despite not using it yet. I will be a lot more comfortable stepping outside of my previous sub 7xx rwhp tuning level now that I am aware of what is needed to play nicely with SBEs.
one thing i didnt consider was that oxygenated race gas already has 9-13% alky in it. kept getting lower readings on my content sensor than i anticipated. derp.
There are several local guys I know who have pump gas cars (like me) and will run C16 fuel at the track/dyno and add a bit more boost but not adjust timing.
Is this a mistake and it sounds like it leaves a lot of power on the table especially when swapping tunes is so easy, this is my current plan btw is to have a two fuel specific tunes.
I guess it'd be nice to know where the tipping point is when going from a leaded race fuel to a E-type fuel is beneficial.
Great thread guys.
Great thread guys.
One of my buddies runs C16 at the track and 93 for cruising but it's a pain to drain it.
A local buddy has a SBF YSI setup and he's only tuned for C16... He's kicking around E85 (and maybe flex) or doing a 93 tune / C16 switch since he can't cruise it. I showed him how much I drive around on pump E85 and how many pumps there are in our area.
