advice needed for ECM/reliable tuner close to me
Project is a pro touring 73 Camaro which I've been putting together since 2019. Motor is a LQ4 with forge rod/flat pistons (9.8:1) 0.005 over, cnc ported 317 with dual valve springs, ARP main and head studs, LS9 gaskets, Summit ghost cam. custom hot side and front mounted (in place of battery) billet S476 T4 1.25 AR, LS6 intake, biggest IC I could fit in front, single walbro 450, 6 and 8 fuel lines and a 4L80E, Strange S60 3.54 rear end.
Wanting very good street manners, 700+ RWHP on 93 with meth. Strong Low to mid range power/torque. I have complete ECM, harness, TB, pedal and module (DBW) pulled with the LQ4, also cable TB with LS6 intake. I can modify the harness myself also, but I don't have any experience with HP Tuners or such. Because of this, considering Terminator X Max also (heard is much easier to set it up and run it at least). Either way, still need a place I can trust for further dyno tune, someone who answer their phone and able to fix possible issues with GM ECM or Holley. I'm not clear how boost control and meth injection can possibly work with GM ECM. Holley can do both apparently, some says go Holley, some more say factory ECM will do the job fine.
So yes...lots of tuning stuff need to figure out which I'm not sure about them.
*** FROST around Richmond VA is 2 hours drive from me, Paid $265 for mail in tune and sent him ECM from another motor I built for a friend to be tuned 3 weeks ago. He doesn't answer the phone or email. Don't know if I ever gonna see that ECM again. This was recommended by some members here. At this point I'm really out of clues.
PLEASE ADVICE...
He did my last SBE LS1 six speed car which made 700whp on pump gas only for years, he's doing my big turbo car as we speak, he's excellent.
You'll have to buy the plug in if you don't have HP Tuners but it's not crazy expensive.
He does all his tuning via scans you send him from driving the car on the street, so you'll get what you want, not a dyno tune that hits a number but drives like crap on the street.
Pat can also tune via EFI Live which is a handheld you plug in and use to scan and upload tunes.
You'll still need a wideband for both, but you'll need one of those regardless even after tuning is complete.
He'll go back and forth with you until you are satisfied with how the car runs and drives, this also means making hits on the street so plan accordingly and find a good spot with plenty of space.
Here's his info, tell him Verne sent you. ; )
Patrick Guerra
The Guerra Group, Inc. |Pat G Tuning
Office: 114 Spokane Avenue | Victoria, TX 77904
Shop: 5002 Lingo Lane | Victoria, TX 77904
361.576.5917 o |361.576.5928 f |713.306.9990 c
So here is the reasons why the Holley Terminator is better.
1- You can potentially get it running yourself with it's self tune stuff.
2- You can use a non-local tuner who can remote into your laptop via something like Teamviewer. You could use someone like Andrew who is a member of this group.
3- You can make real time changes to the tune. Car is running, you can lean it out, add fuel, etc. With HPT you have to download the tune, edit the tune, load it up, log, decide your changes, download tune again. And repeat.
I use both for different cars. My heads/cam car uses HPT.
Starting to think John has stock in Holley lol. ; )
But Holley for a stouter build, absolutely. The real-time tuning is really a must have. Holley (and some other aftermarket ECUs like Fueltech) also give you the ability to control boost in the ECU and the ability to add other inputs that you can then log within the Holley. That list is huge and I don't even know what all the possibilites are, but basically if you can use a sensor to monitor something you can generally pin that into the Holley. Some tuners and racers for example will monitor coolant pressure. So if there is a above normal coolant psi spike you could program the holley to reduce engine timing.
I attempted this but with my work travel schedule, general availability, computer skill level and build complexity, I'd have spent at least a year or two just trying to get it drive able, I only have a four-to-five-month window of nice weather where I live as well.
Pat G's initial tune had the car running better than it ever had out of the box and over a single summer progressed to the point of adding more boost before other issues were uncovered.
Without a doubt it was the best $500 I have spent on the car, once it's dialed, I'll make little changes at the track but for getting going quickly you can't beat it imo.
Good for you for making it work, just don't hurt yourself patting yourself on the back, hate for you to miss a day of work.
If talking something that already came setup with the ECM it would be easier to go with HPT than try to integrate a Holley system, but going restomod just go Holley and be done imo.
Other piece of advice I would toss out is to at least research and have an idea of what the tune is doing. Do you need to learn/know how to build it from scratch? Not by any means, but when a tuner tells you they are cranking up the boost to 18 pounds and feeding it 28 degrees of timing on pump gas with 13:1 AFR, you might want to look elsewhere. You would think that anyone that has a shop wouldn't do anything reckless but you would be surprised how many out there immediately blame "faulty" work or "bad" parts for catastrophic failure.
People always think they have it bad and assume those who are happy or proud of their accomplishments had it easy. Of course I’m proud of my accomplishments, I was raised by an abusive drunk step dad and was homeless at one point. I love America and the opportunity it gave me and everything I’ve accomplished. I’m not sorry for it.
Now, as mentioned, I have all matching electronics came with this LQ4 I've built. Here are pros and cons of GM setup vs terminator x max as I'm looking at them. Correct me If I'm wrong:
HPTuners:
Pros:
- Have ECM, harness, pedal and TAC module in hand.
- Factory diagnostics capabilities - especially if something goes wrong in 4L80E (you can still read DTCs after you tune it, right?)
- OE grade component reliability ( I needed to send my Holley Sniper for repair twice in 5000 miles)
- Will add a good skill, as you guys mentioned. Can be used on other project also.
Cons:
- Still lot more components required ( HPTuner credits, Connector, Wide Band, etc. ) which bring it up past $1200 and probably even further.
- Can't do boost control, meth injection, real time learning, I/Os
- Heard Is hard to get good result with SD tune.
- Still need to go into harness and modify it.
- No safety measures if something goes out of control.
Holley Terminator X MAX:
Pros:
- Easier (than HPTuner)/ No credit needed.
- Self learning capability.
- Comes with everything needed to make it run and tune it (maybe a boost control solenoid and misc. sensors need to purchase separately)
- To my calculation, costs maybe $200-$400 more than HPTuner (or less).
- Works with inexpensive injectors.
- Does boost control, meth, Flex fuel and I/Os.
- Ready to go Harness.
Cons:
- How do you diagnose problems? Other than going back to data logs, I mean...If 4L80E has a problem, how do you diagnose it?
- Reliability. Particularly, this won't be a "track only" car.
