Dead horse beating! S475 vs s480 vs 7875 vs 7883
Old 02-21-2023, 03:03 PM
  #161
02redchevy's Avatar
Originally Posted by forcd ind
Steve Morris has done some testing with the Torqstorm SC's, He just tested the new one with the TS guys at his shop-you can catch him on U tube.
That's what I've been finding. A lot of people seem happy with them from what I can find on forums. I thought they only made 500 crank horsepower when I first researched them but there are guys making 600-700rwhp with them in camaros
Old 02-21-2023, 03:24 PM
  #162
Kfxguy's Avatar
Originally Posted by 02redchevy
Interesting, I didn't think a single 450 would support that! I was wanting to use a boyd's tank with a zl1 fuel pump set up which should get me to around 600rwhp or so, but I may relook at my priorities. 800rwhp is a lot.. I may settle with 600-700rwhp since I don't want to deal with the "next level" of parts in order to do that. I just want something fun, reliable, and easy to work on for the street.
I am currently using an LS3 intake manifold for this build--was thinking about going to the tick set up since it wouldn't be too bad to get the turbo piping figured out, since I can't weld aluminum.
I am really leaning toward the torquestorm as it's cheap and I do like the sound of it.
I already have the engine built, terminator x max(DBW and Trans control). Since I am lowering my power goals(since I refuse to spend so much on a fuel tank) I am going to go with a 258mm circle D single disk lockup. I definitely have more research to do
Go read my turbo build thread. I show a tool i made for super cheap to crimp a bead around the edge of aluminum pipe to keep the hoses from popping off. This was much easier than welding a bead.
The following users liked this post:
02redchevy (02-21-2023)
Old 02-21-2023, 03:44 PM
  #163
LS1Formulation's Avatar
LS1Tech 10 Year
Torqstorm's factory is literally 2 miles from my house. I was planning on going to check it out this spring to see if I might want to get one of their blowers for my SS.
Old 02-21-2023, 03:52 PM
  #164
02redchevy's Avatar
Just went back through and found them, just an old set of crimpers! Nice!
I think the biggest hurdle for me is the intercooler piping if I use a2a instead of an a2w intake system. No matter either one will require it. I only have a little mig welder which is why I'm so limited.
Kfxguy (02-21-2023)
Old 02-21-2023, 05:24 PM
  #165
Kfxguy's Avatar
You could connect everything with silicon couplers and T bolt clamps. You may run into welding a fitting or something but I'm sure you could find someone local to do that for you. If not, I'm sure someone on here could fix you up.
Old 02-21-2023, 06:07 PM
  #166
GMCGreg's Avatar
I can't weld aluminum either but didn't need to , used mandrel bent 3" exhaust tubing when welding was required. On the aluminum tubing the crimping plier bead works perfect- thanks to whoever I got that from !! Can't be sure where I saw it first. Built my whole set up with a lincoln 140 amp mig , I used a bypass valve instead of a blow off so just had to weld 1" nipples to steel pipe , for an aluminum blow off flange to aluminum pipe just mark it out and take it to someone to weld it - a tiny job for a skilled welder .
Old 02-23-2023, 11:52 AM
  #167
02redchevy's Avatar
I spoke with torqstorm, from what I have read/found and from what they explained their base set up should get me to 700rwhp which I think I can deal with LOL especially for a street truck. I will likely go this route out of ease(plus I like the sound!)
I will start with the zl1 fuel module and move up the the zl1 super if I need more fuel
Old 02-23-2023, 12:17 PM
  #168
The BallSS's Avatar
LS1Tech 10 Year
Make sure it has a good warranty.
I'd also make sure you have all the parts and pieces accounted for needed to make it work.
There's a guy on here who put one on his 4th gen F-Body but he had to modify a bunch of stuff and it seemed like in the end buying a Procharger would have been a better bet.
You've got tons of room in the engine bay, just put a basic S475 T6 in there, it'll look cool, make the power you want, spool quickly, be easy to upgrade when you get bored and won't go through belts or require maintenance and have much longer longevity.
Old 02-23-2023, 12:19 PM
  #169
02redchevy's Avatar
I do keep eyeing that s475.. I guess I could do a turbo and hold just limit boost to where I start running out of fuel(I have thought about doing a single 450lph since I know that will fit, I just like the vaporworx set up.
Old 02-23-2023, 12:31 PM
  #170
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,238 Likes on 789 Posts
LS1Tech 10 Year
I've read about a few Torquestorm builds, they tend to be mostly 5th gen Camaros and G8s.
Would you be fabricating a turbo kit @02redchevy ?
Old 02-23-2023, 12:37 PM
  #171
02redchevy's Avatar
Yes, as far as I can with a mig welder anyway
Might try to find someone to help with the cold side,(still might do an a2w tick/holley set up out of ease)
Old 02-23-2023, 12:39 PM
  #172
The BallSS's Avatar
LS1Tech 10 Year
Just do it, you won't regret it, plus you can always sell the S475 easliy later on when you want to upgrade.
Do the divided T6 with the 96mm exhaust wheel, it'll spool quickly and pull to 7,000+rpm easily.
You can run up to 14-15 lbs. on pump gas with a good A2A which most likely will outrun your single 450 but so what.
Run a lower boost at 10 lbs., enjoy the truck, race your buddy, add another fuel pump later and run more boost.
Then add WMI or run a different fuel and go for more, then move to a billet wheel or larger billet wheel turbo and make more.
You don't have to go all out from the start and honestly starting small and working up is part of the fun, at least it is for me.
n2xlr8n66 (02-23-2023)
Old 02-23-2023, 12:48 PM
  #173
02redchevy's Avatar
I think that is a good plan, I think I wanted to start too big at first and I was having my doubts. If I go with an s475, it will have a billet wheel for sure to begin with. I would REALLY like a dual fuel pump set up, but finding a tank that does what I want is proving difficult. I may go with the standard boyds tank and still use the holley dual 450s and just make it work somehow.
The BallSS (02-23-2023)
Old 02-23-2023, 12:53 PM
  #174
The BallSS's Avatar
LS1Tech 10 Year
Cold side piping is easy, I built the cold side for my 4th gen without welding anything so it can be done.
Old 02-23-2023, 01:19 PM
  #175
Kfxguy's Avatar
I tend to think you really don’t know what you want. Lol. You keep changing your mind. You need to set a plan and stick to it. That’s what I did, I bout the turbocharger first which at that point, there was no turning back unless I was ok with losing money. I do not regret anything I’ve done. I drive that car daily too sometimes. Like all this week. Nice weather, taking the car to work which is 30 miles one way.
02redchevy (02-23-2023)
Old 02-23-2023, 01:39 PM
  #176
ddnspider's Avatar
Received 1,751 Likes on 1,307 Posts
LS1Tech 20 Year Member
Big cubes with a shot of spray....definitely.
Old 02-23-2023, 02:11 PM
  #177
The BallSS's Avatar
LS1Tech 10 Year
You don't think someone with a big block would use nitrous or am I missing something?
Old 02-23-2023, 02:17 PM
  #178
The BallSS's Avatar
LS1Tech 10 Year
Do it, buy the billet wheel and commit, turbo noises are awesome.
I love my 4" fender dump, lets me hear everything and I sets car alarms off all the time lol.
For fueling you can do a single in the tank and an external pump on the frame rail or something.
You could also do a 525 pump but to my understanding those require PWM control to operate correctly.
You'll undoubtably run into challenges and you'll find solutions, that's the great part about this hobby.
Old 02-23-2023, 02:41 PM
  #179
ddnspider's Avatar
it was 100% sarcasm. Big cubes ans N2O was the only thing not mentioned now in this thread.
Old 02-23-2023, 02:53 PM
  #180
The BallSS's Avatar
LS1Tech 10 Year
I figured it was something like that, it's so hard to read into that sometimes but at least this thread is entertaining lol.
I could totally see his buddy adding nitrous once he gets gapped by a rusty old pickup truck lmao.
Quick Reply: Dead horse beating! S475 vs s480 vs 7875 vs 7883
