Test fitting the T76.
Old Jul 24, 2004 | 03:19 PM
MYTURBOT/A's Avatar
Unhappy Test fitting the T76.
Well I started test fitting the 76 today and unfortunatly i'm gonna have to clearance the frame some. I need to bend/notch it about a half an inch. It bolts up without hitting but it's just about touching, 1/8in max clearance.
Here are a couple pics i snaped quick of the T76, the 60-1 next to the 76 and the turbo mounted.
Attached Thumbnails Test fitting the T76.-picture-034.jpg   Test fitting the T76.-picture-029.jpg   Test fitting the T76.-picture-035.jpg   Test fitting the T76.-picture.jpg   Test fitting the T76.-picture-036.jpg
Old Jul 24, 2004 | 06:12 PM
69firebird's Avatar
man that looks like a nice turbo there, good luck with it
thanks
ed
Old Jul 24, 2004 | 06:47 PM
MECHAM's Avatar
quite a difference in turbo size there...
Old Jul 24, 2004 | 07:14 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Is that using the on-center housing??
Jose
Old Jul 24, 2004 | 08:17 PM
MYTURBOT/A's Avatar
Yea I had a used on-center housing that he gave me with the turbo since it came with a Tang. housing.
This turbo is freaking huge compared to the 60-1. when i first saw it My first thought was oh S**t it ain't gonna fit. But i got it in there had to pound the frame in just a little bit, not to bad. The sway bar mount also has to be notched quit a bit. All in all i think it fit pretty well. Worked up a base fuel tune for now i'm gonna go out and drive it and see how it feels.
Old Jul 24, 2004 | 09:51 PM
Got Me SOM's Avatar
guess you're bringing that out to the corner tonight.
Old Jul 24, 2004 | 10:11 PM
Packy's Avatar
Nice!
Old Jul 24, 2004 | 10:45 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Where is the turbo then, I can't tell from the picture... which side?
Depending on that info, and what motor mounts you run, you might need to clearance quite a bit... My motor torques up a lot more than I anticipated even with using poly motor mounts.
Old Jul 25, 2004 | 12:51 PM
MYTURBOT/A's Avatar
The turbo's on the driverside in the original TTi location. I'm running the prothane mounts but i also have a torque strap on the driverside that keeps the motor from moving to far so hopefully i'll be ok.
Well first impressions driving it last night. Spool up is way slower then the 60. The 60 would start to spool at 2500RPM and hit 12psi buy 2800-2900RPM it came on real hard real fast. The 76 is extremly slow it'll start to build boost at 2800rpm and gradually clime to 12psi at around 3900RPM, it's nice for traction with the gradual spool up but i wish i had full boost alittle sooner.
I'll have to move my timing tables around alittle now since i'm not building boost as low in the rpm band that might help alittle. Even with the slow spool up I'm very happy with the results, i deffinatly picked up ALOT of power over the 60-1 and it holds A solid 12psi all the way to redline.
Old Jul 25, 2004 | 01:54 PM
GMC SKI's Avatar
How big a down pipe are you running with the setup
and muffler setup are you running with ?
Less exhaust back pressure means way faster spool up
With my 6.0l setup it meant 60rwhp uncapped
Old Jul 25, 2004 | 02:25 PM
MYTURBOT/A's Avatar
Well I'm running a 3in DP now with 3in cat back but i have a cutout right after the DP. Havn't run it with the cutout open yet. I want to get it tuned before i do that.
Old Jul 26, 2004 | 07:29 AM
smokinHawk's Avatar
WHAT AR housing did you choose.
that spool time sounds way slow.
i have the small frame T76 but i get my full 10psi by 2900with full exhaust and around 2700 with the cutout open
3" DP, .96AR cutout right after the downpipe.
Old Jul 26, 2004 | 07:56 AM
MYTURBOT/A's Avatar
Smokin, that's basicly the same setup i'm running 3in DP with .96 A/R. I think once i get the fueling tuned i'll pick up some spool up time, it's running pretty rich in the low RPMs i'm sure.
Old Jul 26, 2004 | 08:03 AM
RICE ETR's Avatar
Turbo Addict
where did you get the T76 and for how much if you don't mind me asking?
Thanks,
-Jarrod
Old Jul 26, 2004 | 12:30 PM
MYTURBOT/A's Avatar
I bought the 76 from a guy that works in a small shop in georgia he ordered it for a customer from TTi the guy made a $400 down payment then lost his job so he couldn't pay the balance, So he sold it to me for the balance he owed on it ($800). Kind of a messed up situation but i got a hell of a deal from it.
