Procharger vs turbo
I'm looking for people who have experience with both platforms. Which one would you pick and why? The LS3 is 10.5:1 static compression. 4.070" cp carillo pistons. 6.125" lunati rods. Stock crank. 0821 frankenstein stage 1 heads unmilled. Cam is a custom cut (see photo). Fuel system is 8an feed with 6an return on adjustable regulator 340lph racetronics pump. I'll be running E85. 3600 stall Turbo400 RMVB with trans brake. 9" inch rear. Holley Terminator to control it all.
This is my first boost build so I'm open to advice aswell. I'm on nitrous right now with the stock ls1. I'm open to keeping the nitrous kit with a 100 shot in play with boost if I need it.
My guess is you will need more fuel pump, of course a boost ref. fuel system. An intercooler would be good, but you are on E85, might be able to run W/O one, I dont have much experience with E85, none around here.
I'm just raggin on turbos but they make nice kits for both . I went with a Procharger years ago bc it was the lest intrusive and it kept ac. This was about 15 yrs ago when I went procharged so the turbo choices were slim .
The Procharger setup also lets your v8 roar like a v8 a turbo is going to muffler it . Me personally I hate when I see cars with fender dumps, to me its cheap and the easy way out . It makes the car annoying and that exhaust usually ends up back in the cabin .
If i went turbo id have a kit that kept ac and a full exhaust .
The guy I bought my current car from had a Procharger P-series blower iirc and while it performed decently, he was only really able to get about 12 lbs. out of it before his IAT's started getting really high and he was constantly fighting cooling challenges as the radiator fan configuration required caused the car to run hot along with belt slip issues.
Now to be fair I had similar issues with a front mount 7875 on my last 4th gen car, a bigger radiator, twin high flow pusher fans and truck alternator were needed and even then, in hot weather and traffic my temps would get a little higher than I liked.
Current car is a T6 setup, has a stood up dual pass radiator, dual fans, Davies Craig water pump setup and never gets over 185 degrees regardless of ambient temp or traffic.
Now, I will say, with the newer electric wastegates, if you had the ability to control one, and put it on a Procharged setup, that would help even things out a little. There's still no scramble button, and you can't just turn the boost up as easily, but I will say, they are cool.
I don’t really care what others use if I’m happy with what I have why change?
I’ve had turbo and blower cars. Really isn’t even a comparison with cheap turbos these days. I love the sound of an obnoxiously loud blower. I ran the old P600B which I believe was one of the loudest centri blowers. It ran well, and I really liked it. But when a $400 China turbo will make more power per pound, I don’t see how people can afford to not go turbo.
Working on an F1 installation now into Fairmont with a SBF and its been a pain. Had to make room for the 12rib, change accessories, remote mount water pump, etc etc… It nickel and dimes you to death ON TOP of the ridiculous initial cost for the kit. He has a mint into fittings and lines just to remote mount the water pump. It will run really well I’m sure. But its twice the work and 10x the cost of a factory manifold DIY turbo kit…if not more.
Spending more for less is a personal choice and a luxury. If it’s in your budget and you want blower noises… more power to ya! No need to ask which is “best” at that point though. Which is best isn’t an opinion, it’s a fact. If the 2 power adders are in a “fight”. The Turbo’s on top every time.
