Summit Ghost Cam. Power limit on boost? Kind of a what will it make thread??
Old Jun 23, 2023 | 08:12 PM
  #61
dawgs74's Avatar
So does this cam make enough vacuum to power the brakes??? Im building a 408 with the same compression ratio and LSA supercharger setup and was trying to figure out what cam to go with that will still be streetable and vacuum friendly……did you ever switch out the ghost cam for something else??
Old Jun 23, 2023 | 09:34 PM
  #62
Mr. Black's Avatar
Still running this cam. No regrets. Couldn't ask for a better driver cam especially with a manual. Minimal chugging at low RPMs. Will easily turn 6th gear at 60mph at like 1300rpms.
Zero problems with vacuum and the brake booster in a C5 chassis. It has no overlap.
Old Jun 23, 2023 | 10:52 PM
  #63
Kfxguy's Avatar
I have it in a 5.3. No drivability issues. Pulls 12-13 inches of vacuum at 600rpm in my low compression engine.
Old Jun 24, 2023 | 08:19 PM
  #64
wannafbody's Avatar
Ghost Cam is probably a bit small for a 408.
Old Jun 24, 2023 | 08:22 PM
  #65
Mr. Black's Avatar
I agree. I wish they made an extra large Ghost Cam lol.
That being said, once boost is involved I don't know if it's that big of deal in larger cubes.
Old Mar 2, 2024 | 01:45 AM
  #66
dawgs74's Avatar
Did you get away with using 7.400” pushrods on that cam???….u still running it??
Old Mar 2, 2024 | 10:55 AM
  #67
Mr. Black's Avatar
Yup still running it. Probably have around 4k miles on it.
IIRC I had to go shorter for my combination. Cleanup pass on the heads and decked block.
7.385" I believe. It probably would have been fine with 7.400s but the preload was a little too much.
For ***** and grins I did spec out a more custom cam from Cam Motion last month giving them every detail about the car and combination. It is a very thorough questionnaire they ask for.
The cam they came back with was basically their largest street based blower cam they have I'm sure mostly factoring in the 408 cubes part of the combo. It is a monster. I'm a little hesitant to try it.
238/254 119+4
They also said the Pac Beehives would not be wise and to switch to their dual spring kit.
Old Mar 2, 2024 | 03:12 PM
  #68
dawgs74's Avatar
Yea i seen that cam too, im hesitant as well cause its probably not too streetable…..i have a cam motion 220/230….117+3 in my 370” LSA supercharged LQ9 and its perfect….wish i could just put it in the 408 but i know it would be too small
Old Mar 2, 2024 | 03:17 PM
  #69
dawgs74's Avatar
Do you know if they said that cam would pull enough vacuum to work the brakes….thats my biggest concern??
Old Mar 2, 2024 | 07:39 PM
  #70
Mr. Black's Avatar
They didn't say anything and I can't imagine it would be a problem. These cams have little to no overlap. Worst case scenario, turn the idle up a little bit and I'm sure it would clear up.
Old Mar 3, 2024 | 01:42 PM
  #71
wannafbody's Avatar
I've got a larger 227/234 cam and have never had an issue with the brakes.
Old Mar 3, 2024 | 07:51 PM
  #72
jester1's Avatar
Off topic but noticed you have a gladiator, how do you like it towing the car/trailer?
Old Mar 13, 2024 | 04:23 PM
  #73
JumboShrimp's Avatar
Great Work, Mr. B! You are still my idol
I would have guessed closer to 700 but I know you are conservative and will creep up on that number - easy peazy for the guts it has.
Upon the advice of Ron and other people WAY smarter than me I am ditching the SD tune and adding a card style MAF. Finding room is the hard part. 20# of Poo / 5# Bag. Mine has been down all winter but I'm making time to work on it. I also found a different / better? adapter plate for the cathedral - rectangular issue. It has been a S.O.B for Ron - hopefully, he'll have me back.
I also found a tiny vac leak where the AC hose hooks to the blower - that little hole could have caused a big problem. Dunno?
Keep up the always fine work. And using cool words like 'tutelage'. LOVE IT !!
Old Mar 13, 2024 | 05:04 PM
  #74
Mr. Black's Avatar
Thanks Jumbo.
Somewhere in this thread I think I showed how I put an LS3 card style MAF in my intake using a 4 inch pre made tube.
I didn't keep it though because the 3 bar operating system wouldn't fully recognize it and work properly. So I ended up removing it and selling it.
Yeah, I could have went back to 1 bar operating system and ran the MAF but in my case the car drives so well that it wasn't worth the time and effort IMO.
P.S. I am thinking about making the switch to a Whipple 2.9 liter C6 rectangle port blower lol.
Old Mar 13, 2024 | 05:12 PM
  #75
Mr. Black's Avatar
I don't know how I missed this. Apologize for the delay.
We loved out Gladiator but absolutely hated that POS 3.6 liter pentastar engine.
This one had the Max Tow Package as well. Most I ever towed with it was around 6500lbs and it pulls it great and handles well. With or without weight distribution.
Two biggest negatives, Gas mileage SUCKS even not towing. Gas Mileage MEGA SUCKS when towing especially an RV with all the drag.
The range while towing blows ***** at 7mpg. Also when towing the RV it would just stay at high rpms and when going cross country it is very annoying, I also have no doubts we would have eventually blown it up. That engine is known for blowing up even without towing lol.
So we ultimately decided to trade it off for something a little more comfortable for our towing needs without going back to big diesel 1 tons which we've had several of over the last 20 years.
While we miss the Gladiator, especially the wife, I am absolutely loving the low mileage 2017 Ford F150 Platinum 3.5 Ecoboost that we got (also has the 36 gallon tank).
If you have any other Gladiator questions, by all means fire away.
Old Mar 14, 2024 | 10:36 PM
  #76
jester1's Avatar
Hi, no worries thank you for answering a off topic question! Thanks for your honesty its exactly the answer i was looking for. I rent jeeps all the time for work love driving them so I was talking myself into a gladiator( only had one of these for couple days) to avoid a truck and have best of both worlds. Something really told me I was fooling myself.
Time for a truck or might do a jeep for daily and old truck to tow to track which is only really have dozen times as year. Guess well see what happens maybe Ill say f it and get a vette that identifies as a truck lol.
BTW love the vette.
Old Apr 7, 2024 | 04:18 PM
  #77
Mr. Black's Avatar
So now I am looking at the Summit 8722R1 (stage 3 turbo) cam for the LSA 408. Not nearly as gnarly as the one Cam Motion wants me to try but a good bit bigger than the ghost cam. Still not much overlap which is good. 234/238 .625 .605 115+5
and the damn thing is on sale until the end of the day lol.
Old Apr 7, 2024 | 04:20 PM
  #78
dawgs74's Avatar
Tempting aint it!!!…..is it $349 sale price or normal price??…..their LS cams used to be $299 just a year or 2 ago……
