JW Ultra Bell TH400 Yes or No?
Hello gents,
Looking at a JW Ultra bell for my TH400 in my 1999 Camaro.
Trans is currently equipped with a transbrake, on a radial tire, single 84mm turbo, LS1 5.7 but will be LC9 5.3 in the future.
Will be around 800 whp on pump gas and 900-1,000 with meth but mostly ran at 800whp shifting at 7,000-7,500rpm.
More street than track, might see the track 6-8 times a year.
Is an Ultra bell a good idea or overkill for what I'm doing?
Probably overkill at the 800 mark, but will spending around $1000 for the bell and machining make you feel more comfortable when you lean on it? Do you have a SFI flexplate at minimum?
I think at the 1000whp mark with an OEM block that it starts to make more sense to have some additional safety items in place. It's always good.... til it isn't.
I was watching Raceweek coverage, and a guy had his bellhousing break and spin the trans in the car and tear a bunch of stuff up so it got me thinking.
I'm not looking to cut stupid low 60' times with it or high rpm trans-brake launches, it makes 5 lbs. on the brake at 3,000rpm which I'll probably have a hard enough time with lol.
It does have an SFI flexplate in it and a transmission blanket over the top, didn't wrap the whole thing due to heat.
I won't be doing a whole lot at the 1Kwhp mark, factory crank, and block won't take too kindly to too much of that, the occasional hero dyno/pass run is about it.
They used to be a couple hundred bucks.....I did my own, it was pretty easy.
Either the bell or a shield is required if you go to an NHRA track that bothers to check.
I also believe you can get one that uses the top bolt on the LS which adds an extra measure of attachment.
If not taking it to the track, I don't think I'd bother.
Just a fast street car that may see the track if the opportunity presents itself.
ATI makes a nice one for $350 and my trans guy said he'll install for $100 which is tempting.
Hey I know this is old, but I thought I could add something that may help. I have a fabrication/machine shop and back in 2010 or so started repairing cracked transmissions and bell housings for local guys. Most of the guys that blow apart th400 bells are offloading/rock crawlingfrom what I saw..
I started running tig welds on the bellhousings as reinforcement ribs building out the weld about a 1/4" high running welds the length of the bell, and then wrap a few across the diameter of the bell as well.. have never seen one I reinforced break afterwards..
I didnt have much of a choice as my case had a couple holes broken off but bit the bullet and bought one. When my tranny guy built mine I had him cut off the old and install the new.
For me it was a need and gave me piece of mind. I think right now im shooting for 800 hp but like the idea that if it comes apart my legs will be okay.
As my old man said before I built it, how much are your legs worth?
I invested in SFI rated components there, so the bell housing is secondary or at least until the trans comes out for a refresh.
