Crankcase /PCV System / Boosted application. Ls3
Can someone provide me with the best way to plumb this for an:
-Ls3
-No Port coming from valley pan
-Gen4 Throttle body
-Vortech Supercharge up to 10lbs boost
-Catch can has 2 ins and 1 out (dont have to use both ins) it also has a breather on top if I want to use.
-Ls3
-Gen4 Throttle body
Lool at Mighty Mouse catch can. That's what I had for my old ls3. Still have that on my built 402, after my ls3 took a dump. Also have a centri blower too.
Also you want to generally avoid locating the bung in the back near the firewall, the lines will ingest more oil than is ideal when you are accelerating (oil slops back).
If you look at the location of the bungs on very fast LS race cars they are usually up high on the valve cover located in the middle or in the front.
Running a 3/8 line from the rear driver's valve cover (built in tiny orifice) to the intake manifold with a check valve to prevent boost from pressurizing crankcase. Driver's valve cover nipple capped. I have a large -10AN oil filler adapter running a -10AN hose in front of the turbo impeller. No catch can.
Under vacuum it pulls fresh air in through the filler cap vent and through the crankcase, picking up crankcase gases and making its way to the intake manifold and being burned.
Under boost the check valve closes, and any blowby (excessive crankcase pressure/oil fumes) comes out the -10 vent and is sucked into the turbo to be burned. I have zero smells and the end of the -10AN hose is bone dry (no liquid oil being ingested into turbo). The filler cap adapter fitting is a fairly tall 90 and the hose runs slightly uphill to prevent any oil splashing out. If I had room for a filter on the turbo I'd connect that hose to the filter for a cleaner look.
You've got me on the unfiltered part, but it's hardly the first time someone has run no filter on a turbo LS.
But "giant" vacuum leak? The intake manifold is trying to suck through a 1/16" hole in the valve cover baffle...it idles fine. There is no MAF.
The reason the filler vent is so big is to vent blowby. My setup is very similar to forcd ind's except he's running a container. Both have open breathers on the filler and a vacuum source from the intake. Again, how else do you suggest bringing makeup air into the crankcase if you're removing it on the dirty side?
