IATs and Recoating Headers
Old Apr 28, 2023 | 09:02 AM
JoeMama's GTO's Avatar
Default IATs and Recoating Headers
Running an F1A-94 and about to switch from 1 3/4 to 2 inch headers. The 2 inch headers are coated black, question is would it be worth it to recoat the headers in a chrome/silver coating to reduce radiant heat? My IAT's run pretty hot,160-170 at the end of the quarter. No options for relocating intake but I am looking into a cowl hood. They want $325 for the recoat, what do you guys think?
Old Apr 28, 2023 | 09:23 AM
Black_Sunshine_99's Avatar
Wrap them, I had wrapped headers on my BBC N/A and it brought under hood temps way down and looked better to boot.
Old Apr 28, 2023 | 12:20 PM
Hmm, I could wrap them, just a couple areas I would have to be careful because of tight clearances.
Old Apr 28, 2023 | 01:34 PM
Soak the wrap in water and then wrap them, wear gloves lol.
It really knocks the heat down way more than ceramic coating, take you time with install so you don't damage the wrap.
Old Apr 28, 2023 | 03:16 PM
275Camaro's Avatar
Good to hear some real world experience. I have used Jet Hot coated headers and wraps on exhaust before, but never had anyway to measure any improvements other than my foot not getting as hot I guess.
Old Apr 28, 2023 | 04:16 PM
pdxmotorhead's Avatar
If its a real baked on ceramic, its about 80% as effective as a wrap without the benefit
of rusting out the pipes or cracking them from overheating. the white or medium
silver ceramic seem to have the best results, Ideally you want them coated inside
and out but if they have been used thats more difficult.
Of course I live in the Pacific North-Wet and its just when something will finally soak up water...
With the silver, on a 410 sprint I can touch the pipes bare handed within just a couple minutes of coming off track.
without the coating it took 20 minutes for me to be able to put my hands in around the motor.
Old Apr 28, 2023 | 04:48 PM
The headers are stainless so they shouldn't rust. Seems like if I avoid wrapping near any welds the pipes shouldn't crack from overheating. Think I might try the wrap, hopefully it doesn't exhaust (pun intended) my patience getting it on there.
Old Apr 28, 2023 | 05:23 PM
I've spent many years at the track taking care of other folks cars, I've never seen a wrap that didn't cause problems eventually
Cracking,
Corrosion
Absorbing oil and catching fire after maintenance or repair <-I have seen this way too often. If you spill oil on the wrap replace it..
Its kinda like some car wrapping techniques.. On car bodies, they have a life expectancy.
So just plan on regular replacement.
Stainless in my experience cracks as often as mild steel, but its mostly due to poor weld quality, stainless needs back
purging while welding to get the best result and not all manufacturers do it.
Time vs money.. LOL and their warranties typically expire before a problem shows up.
I have installed wrap for customers, I never do headers on the car.. And I use the DEI titanium.
Old Apr 28, 2023 | 06:36 PM
Cracking,
Corrosion
Huh, tough call then. Not interested in cracking expensive and discontinued headers Maybe I will just look to improve airflow to the intercooler/engine compartment. Also, doesn't seem worth it to recoat from black to silver/chrome.
Old Apr 28, 2023 | 06:42 PM
It depends on the quality of the original coating, FWIW, you can 80 grit blast the headers and use cerocote on them, (You can do it yourself order direct) They have an Air Dry product that will bake out with use.
I added a duct on each side of a car just to carry air to the sides of the motor, used the 4" aluminum tube, it wasn't fancy but at cruise it cooled the hood off..
air flow is your friend ,, a rear hood lift helps a ton, spacers under the hinges/remove the rear gasket on the hood if its still there.. Poor mans ram air..
If you use a wrap just commit to replacing it every year or so depending on weather and mileage.. Its the water getting in the wrap and soaking against the pipe thats the normal issue.
Old Apr 28, 2023 | 06:47 PM
BCNUL8R's Avatar
I run the same blower and my IAT barely gets above ambient. In fact it actually starts dropping below ambient at wot, but that is misleading because I use methanol before the IAT. Before the meth and an overspun D1x it barely ever got above ambient during wot pulls even multiple pulls back to back.
I have removed the under hood insulation, wrapped headers, no ac, and the large procharger air to air intercooler. I also use 50% ethanol as a main fuel. I also have a BTR aluminum manifold.
When I had a stock ls6 intake manifold one of my fuel rail bosses broke allowing the rail to raise and expose the fuel injector o-ring. I was spraying fuel all over in the engine bay. No fire. It was all over my wrapped headers everywhere. I'm convinced the wrap actually prevented a fire as I have them double wrapped and can grab them with the engine running with my bare hands. An unwrapped header would have ignited the fuel.
I have an 8.25 crank pulley and 4.13 blower pulley on the F1a-94 shifting at 7000-7200 rpm no IAT issues.
I've had my headers wrapped for 4 years without issues.
Old Apr 28, 2023 | 07:37 PM
What headers you running? We have similar setups except I am running a treadstone 3.5" intercooler and my headers are not wrapped. I even spin the procharger to a similar RPM. What boost do you see since its directly related to IATs?
Old Apr 28, 2023 | 08:10 PM
BCNUL8R's Avatar
I have 6 year old stainless works headers. I bought this car about 6 years ago and they were the first mod I did. Roughly 20 psi peak. The intercooler I have is the "1300 hp" procharger intercooler. I run no air filter only a blower guard. 160 t-stat fan on at 179 degrees.
Old Apr 28, 2023 | 08:30 PM
Nice, thanks. I am running a couple more lbs but not enough to make a big difference. Looks like I be wrapping the headers and thinking about that expensive *** intercooler. Probably get a VFN cowl hood instead of the intercooler to lose weight and shed heat.
Old Apr 29, 2023 | 08:02 AM
BCNUL8R's Avatar
What is your engine combo?
Old Apr 29, 2023 | 12:42 PM
jordoza's Avatar
I use the dei lava wrap on my headers and stuff on my turbo set up. Didn't have to soaking in water or anything. Replaced it a few months ago during a refresh because it had to be garbage but it was like brand new and that is lots of quarter passes and probably 10k miles of Mexico driving. Wrap outlasted Mt Trans 3 times over. Lol
Old Apr 30, 2023 | 08:48 AM
Forged aluminum 365, FAST 102 intake, 230/242 cam, 9.6 CR, ported 243 heads, and currently 1 3/4 headers. Want to get boost down to help with IATs so I am hoping that the larger headers and eventually LSA style heads will help with that.
Old Apr 30, 2023 | 11:24 AM
BCNUL8R's Avatar
I dont think it will. I think your problem is elsewhere.
Our setups are so similar it's crazy...lol...377 forged Ls3 block...232/248 cam... 10.6 to 1 compression... junk heads... 1 3/4 headers... aluminum intake which shouldn't be as good as your fast...etc...and I don't have any iat problems.
I also don't think the LSA heads are that great without good port work.
Old Apr 30, 2023 | 02:52 PM
I agree, so I am wrapping these headers and going to a cowl hood at some point. If I find a good intercooler for short money will grab that too, but that procharger race intercooler is a friggin mint if you buy it direct.
Old Apr 30, 2023 | 03:25 PM
BCNUL8R's Avatar
Yep, I bought my kit with a D1x head unit and all the upgrades about 5 years ago. At the time the intercooler was about a $500 upgrade so it made sense knowing I'd only want more later. This winter I sold the D1x and bought the F1a-94.
Air flow is your friend allowing air in and hot air out. That along with wrapping the headers will help a bunch.
