Procharger guys - Help
- 421ci iron block (made 500rwhp N/A on 91)
- Stock ls3 heads
- fast 102/102
- 1 7/8 headers to cutout
- 6 speed transmission
- NEW D1X head unit with helical gears
- 8" crank pulley and 3.85" head unit pulley (spinning roughly 55,000rpm)
- red race BOV
- 10 rib with "new" auto tensioning bracket
- FMIC
- e85 fuel
- chris1313 dual 525 set up and new PTFE lines (-8an feed and return)
The set up only made 7 psi with no filter on the front of the head unit and 4 psi with a turbo guard on it.
Tuner is very credible and knows his stuff. He checked it over as well and couldn't find any leaks or belt slip. Made 710/650 when it was all said and done.
Anybody have any insight or thoughts on this? What have you guys made with your setups and what do they consist of? Thank you in advance!
My car with a baby cam made over 800 with a standard D1SC spinning around 58k with small ls2 heads, air filter, aster 8 rib belt huge intercooler on 93 pump. You're setup is better on all areas so should be making quite a bit more than mine. Got to figure this out!
It made 500 rwhp N/A and now at only 7 psi of boost on a D1X it's making 710 rwhp, well that lines up with what I would expect to see and doing simple math it checks out also. If you want more power you need more boost, E85 will support whatever you throw at it with that blower so crank it up.
Comparison with my old setup:
++ 421ci iron block (made 500rwhp N/A on 91) vs 370ci iron block
?? Some cam vs Baby blower cam
++ Stock ls3 heads vs TEA cast LS2 215cc
++ fast 102/102 vs Fast 92
++ 1 7/8 headers to cutout vs 1 7/8 header with full exhaust to bumper
6 speed transmission vs same
-- 8" crank pulley and 3.85" head unit pulley vs 8.65 / 3.85" spinning 62k at 6800
red race BOV vs same
++ NEW D1X head unit with helical gears vs D1SC with helical gears
++ 10 rib with "new" auto tensioning bracket vs 8-rib Aster
-- FMIC vs 6" Shearer Big *** Intercooler
++ e85 fuel vs 93 pump and meth kit
++ No filter vs 90 degree elbow and large cone filter
This setup has 8 power advantages. Only advantages my setup have is the blower was maxed out and maybe the intercooler, yet his setup makes 100hp less with a blower capable of producing 150 hp more?
At 6800 the D1X is spinning 58k with the 3.85". It would take a 3.40" to get to 65k. No way it gains 200-300 hp on a pulley swap. But I'll eat my shoe if it does!
Built and currently tuning a C6/M6 LSX 427, 9.82:1/D1X/3.4" pulley and it's currently making 12.5 PSI at 6800 rpm(Turbo guard stainless mesh screen). Apples to oranges comparison as this set up has Cathedral port PRC 247 heads/BTR equalizer 1 intake. 10PSI with the A&A dongle/ K&N filter. Will see what is does with the Turbo guard standard (larger hole) screen and 7k RPMS.
The only relative comparison you can make is what his engine made N/A vs what it is making now on only 7 psi of boost. If there was something really wrong (boost leak, intercooler restriction, etc) it would not be a near perfect match doing the math on what 7 psi of boost should do on HIS engine. The most I've ever seen a D1X make (on a standard dynojet with no tricks) was about 950 rwhp and that was overspun slightly with a highly efficient A2W intercooler, and yes I know what they say it's rated at.
Moral of the story, spin it faster and see what happens and go from there because it's making exactly what it should be at only 7 psi of boost and if there was really something wrong you wouldn't see these results.
We are currently in the process of building a bad 408 for the car and the Frankenstein m311’s are already at my house ready to be set on that motor when it’s done. Then I will be ordering the pulley to spin the procharger wide open.
You guys think it’s okay to overdoing the d1x? I was going to order a 3.55 which would bring it right to that 62k range.
Regardless, lot of good knowledge and replies here so again, thank you. I will reply with the new numbers when it’s all done!
Why build another motor and not just change the cam and pulley on the blower? That is probably all that is actually needed.
