Flexfuel sensor location
Old May 28, 2023 | 07:37 PM
Impalablazergang's Avatar
Default Flexfuel sensor location
At the point where I'm placing the flexfuel sensor, I like the placement of it attached directly to the return port of the fuel pressure regulator. It'd be the cleanest/shortest length for my wiring but I don't know if being attached like that is going to cause issues or if I should have it a little further down stream. Any opinions on this would he appreciated
Old May 29, 2023 | 08:16 AM
fucter's Avatar
I had to put it near the fuel filter, there just wasn’t enough room anywhere else. Would have loved to fit it under the hood somewhere
Old May 29, 2023 | 04:37 PM
Lsxford's Avatar
I have mine about 2 feet after the fpr and it was fine driving around and tuning. Went to the track the other day and during the pass the reading fluctuated from 70% to about 50% which was throwing off some of my custom tables. I tweaked the frequency the ecu averages the data and will tweak the tables if I need to. I'm guessing there is air or just turbulence in the return line. Not really an issue for me since I knew the % was good so it's staying right where it is.
Old May 29, 2023 | 06:56 PM
BigBoyWS6's Avatar
Before or after the fuel filter? I need to find a good place also.
Old May 30, 2023 | 11:28 AM
NicD's Avatar
7 Second Club
It's uncovering the sensor inside since it's not returning enough fuel, that's why you don't put it in the return line after the fuel pressure regulator unless you have a better computer that can latch ethanol content before going WOT. I have found the best place is after the fuel rails before the regulator so it's under constant pressure and is not a restriction feeding the rails. Or get one of those fancy Motion Raceworks flex sensor bypass units and just stick it in the feed line and not worry about it being a restriction.
Old May 30, 2023 | 11:34 AM
TrendSetter's Avatar
shouldnt it just stop flowing and not see 'air' since theres nowhere for the air to come from?
Old May 30, 2023 | 01:21 PM
NicD's Avatar
7 Second Club
If fuel just drains into the return and it's not under pressure it most certainly will "uncover" the sensor depending on where it's located, etc.
Old May 30, 2023 | 01:43 PM
Tommy42088's Avatar
My feed line goes into regulator, from regulator to drivers fuel rail, and passenger rail goes out to flex fuel sensor, flex fuel goes to return. No issues, holds 58 psi. My fuel rail regulator is mounted to firewall besides brake booster and the flex fuel sensor is hidden behind the intake manifold.
 Michael S. Palmer
Old May 31, 2023 | 04:57 PM
275Camaro's Avatar
I'll bet it holds 58 psi when you run your injectors on the return.
Old May 31, 2023 | 05:09 PM
Tommy42088's Avatar
My injectors arent on the return, im just telling op how i have mine setup. Its his choice how he decides to do his. Why would i move my injectors to the return? Mine works fine how it is
Old May 31, 2023 | 05:43 PM
275Camaro's Avatar
The regulator normally goes after the injectors. If it is before the injectors, how would you know what the pressure is at the injectors?
Old May 31, 2023 | 08:24 PM
Lsxford's Avatar
I 100% agree with ya. But like I said it's not an issue for me personally because I already know what the percentage is before a pass. What it reads going down track doesn't bother me. If it was a street car where I was relying on it full time yes put it in the feed line, although the only time mine fluctuates is making a hit. I was just answering the op's questions. I also have 1 of the sensor bypass deals but from radium iirc, may not be helping the uncovering situation.
Old Jun 1, 2023 | 12:21 PM
NicD's Avatar
7 Second Club
But you don't want the ethanol percentage moving around at all during a hit as that gives the computer false information and changes it's fueling/timing incorrectly. Having that happen during a WOT run is the worst case scenario.
Old Jun 1, 2023 | 01:28 PM
Black_Sunshine_99's Avatar
Totally agree with @275Camaro , as an example, my fuel feed goes to the front passenger side fuel rail, connects from the rear of the passenger rail to the rear of the driver rail with the BRFPR mounted on the front driver side rail with the return going back to the tank.
Ideally, I think a Y should be used but this arrangement hasn't had any issues.
Old Jun 1, 2023 | 02:21 PM
ive been running the inlet from the pump in one side of the regulator and the feed to the stock truck rails from the other side for years and its been fine. i have never really pushed any limits but i dont see how that would be a limfac before the stock tbss rails themselves.
Old Jun 1, 2023 | 03:16 PM
Lsxford's Avatar
It only affects it if you tell it to. But regardless this thread isn't about my pile of ****.
Old Jun 1, 2023 | 03:22 PM
275Camaro's Avatar
Stock TBSS is returnless. Different story.
Old Jun 1, 2023 | 04:48 PM
Tommy42088's Avatar
I actually said it backwards after I looked at it, feed line ito flex fuel sensor, from there to passenger rear rail, rails connected in front, and drivers rear goes out into regulator then, and the return is on the bottom port of regulator and the other fuel port on the regulator goes into my nitrous fuel solenoid
Old Jun 2, 2023 | 09:15 AM
MM told me that factory return less style systems start having delivery consistency issues above the 700-800whp mark.
I ran the factory return less fuel system on my 02 Camaro at 700whp for years, literally twin 255's with one on a Hobbs switch, everything else was stock lol.
Identical to mine basically, the only downside I've been told is that when you reach the limits of the pump or pumps, the rail that gets fuel second would see reduced pressure to those injectors, but I think that's a very extreme case and I've never heard of it actually happening to anyone.
I think with fuels that require significantly more volume like E85 and Methanol, then equal distribution to each rail becomes more of an issue.
Old Jun 2, 2023 | 10:12 AM
Tommy42088's Avatar
interesting, I haven't had an issues yet, honestly all I ever use is e85. I haven't reached any extreme power yet either. I'm only at about 550rwhp but after this louisiana summer heat passes I plan to add a second pump and a procharger on the truck so I guess I'll see how it works out when I go that route. My tuner that also owns a performance mechanic shop is actually the one who put my lines like that. I had them hooked up different and he switched them to the way they are now a few months back and he builds alot of cars with much more power then mine. The only thing he mentioned was switching the injectors and adding a second pump in which I already had that planned.
