Term X fuel pump trigger
How are you guys doing it or have done it.
I called Holley multiple times to see if I can get tech on the phone but hours on hold to get one person and not answering my question.
I am wiring in my terminator x and this is one of my big questions.
I did the twin racetronix with intermediate harness and am not sure how I want to go.
I was thinking I could get away with both on a single 40 amp relay triggered by the green wire.
-Cody
Forced you are correct it is shared with injectors and coils from their diagram.
I know this is trivial but id rather ask a dumb trivial question than burn up an ecu if I don't have to.
I mean if you're worried about limited outputs why not put it on a switch?
I'd prefer to have the 2nd pump on a Hobbs switch, but I'm just trying to answer your direct question.
ha that's why I'm so confused as to why Holley said don't do that. It makes zero sense that you cant trigger 2 relays that would probably draw 1.5 amps combined?
I thought if I ask here someone may have gone through this as to why or have back door knowledge as to why not to do it.
Either the guy at holley misunderstood your question or doesn’t understand how relays work.
