Haltech Nexus Rebel LS
Nexus Rebel LSCOMING SOON: NEXUS REBEL LSAre you ready to Rebel?The latest addition to the Haltech Nexus Range is the Nexus Rebel LS, specifically designed for LS Gen 3 and 4 engines. Included in the kit is an easy-to-install engine harness kit, and start-up is a breeze thanks to the new LS Set-up Wizard in our NSP software, or via the new Haltech Connect App. With the Rebel LS, all the hard work is done. It is the best, quickest, and easiest way to get your LS-swap up and running! • ECU designed from the ground up to suit GM’s popular LS engine platform• Supports both Gen III/IV engines• Comes complete with an easy-to-install harness to suit multiple GM LS applications• Easy set-up via the new Haltech Connect app• Easy integration with Haltech dashes, PDMs, sensor kits, and accessories.
JUST THE FACTS
OUTPUTS
Ignition 8 Pre-Configured Outputs (High Impedance Only)Injector 8 Pre-Configured OutputsLow Side Switched / Digital Pulsed Outputs (DPO) 425A Outputs 3 x Dedicated (Ignition / Injection, Fuel Pump and Cooling Fan)1 x User Definable
INPUTS User Definable Analog Voltage Inputs (AVI) 2Engine Position Inputs 2 Dedicated Crank And Cam inputsUser Definable Synchronised Pulsed Inputs (SPI) 4 (Can Be Programmed For AVIs)Pre Configured Knock Inputs 2On-board Wideband Controller (LSU 4.9 Only) 1 (Expandable To 10 With Haltech CAN WB Modules)Ignition Switch Input 1
COMMUNICATIONS
CAN Bus Networks 1 Dedicated Haltech CANHigh-Speed USB 2.0 (USB-C interface) 1On-board Wi-Fi YESOTHER On-board Data Logging 32MBOn-board MAP Sensor 4Bar (Absolute) / 43.5 PSI GaugeOscilloscope 4 Channel5V Sensor Supply 18V Sensor Supply 1Sensor Ground 1
FEATURES
Easy Set Up Wizard YESDrive-By-Wire Throttle Support 1Flex Fuel YESClosed Loop O2 Control Dual Bank (Requires Additional Sensor / Controller)Knock Control DualVariable Cam Control NOAuto Trans Control Coming SoonLong Term Learning YES – 3DData Logging Laptop + OnboardAnti-Lag Rotational Idle YESLaunch Control YESTraction Control YESTuning Table Resolution 32 x 32 – 3DEngine Protection Multi-LevelCAN Networks 1 (Haltech CAN Only)Nitrous Control YESBoost Control 3D Closed LoopFlat Shift Control YESShock Travel & Ride Height YESRace Timer YESDriveshaft And Engine RPM Targeting NO
I can't see it being cheaper than the elite 2500 with harness (2,800$), or R3 with harness ~ (3,200$~3,800)
So likely not a terminator X competitor but may force everyone to step up their game. I know MSD/Holley has some products upcoming that can do tune by app via blue tooth connection to phone
My buddy is at SEMA and I asked him to ask some questions for me. If anyone has any questions I can pass the word along to him to harass em
the haltech will absolutely be a better ecu. Whether or not it’s price point makes it a valid comparison is yet to be seen.
I tune Terminator X and X Max ECUs everyday. Do they have their issues, of course, but I promise you that every manufacturer has their skeletons that occasionally fall out of the closet. LOL
Andrew
https://www.hptuners.com/core-ecu/
Andrew
Andrew
Andrew
by better i mean its just a higher end piece and the price will certainly reflect that, its just up in the air what that price difference will be and how easy it will be for people to jump that gap. can you argue that a HP is not 'better' than a terminator x ? i dont mean to say the terminator x is total trash, it has its place and has probably done more for the ls swap community since it came out than just about anything.
Andrew
https://www.hptuners.com/wp-content/...Comparison.pdf
