The Turbo TA is BACK!
Old Nov 18, 2025 | 01:20 PM
  #141
ScreaminHawk's Avatar
yay work of which i paid someone else to do but didn't do so now i have to do it!!
Old Dec 8, 2025 | 09:08 AM
  #142
Broke EF's Avatar
Well I managed to spend some time in the garage this weekend. Mostly just getting frustrated if I am honest. I have been trying to kind of reverse engineer the base chassis set up, which is something I know nothing about. To me, step one is setting the ride height, and then I can work with whoever to measure for coilovers front and back. The questionable part has always been the front suspension and how low can that go while still working correctly. I started asking other f-body guys I know what they are running and they said MWC just like me. Well this is the very first set of front suspension they ever made, so its not unreasonable to think they have changed things. I say this because I already know it cant get as low as other cars without binding up. Weeks ago I had taken the coilover out of the driver front and tried to set the center of the hub where it would need to be, and it didnt get there.
Anyway, I wont bore you guys with everything but its been a pain in my *** for weeks. After ******* with it for way too long Saturday, I still dont know if its OK or not. Lets get into pics and I can explain.
This is the driver front wheel as low as it can possibly go.
You can see, no suspension in the car, but both ball joints are bound up.
So from multiple people I have been told to set the ride height at 4-4.5" from the pinch weld. I know of a car that is at 4" and is able to go lower with the same suspension as me, and his is nowhere near bound up at 4" So lets see where I am at.
Very slightly lower as you can see. Also, keep in mind that throughout the whole build I was told it was being built for a 3" ride height. Clearly that was a lie. But this then had me thinking, IS this where I should measure? Here is a wider shot of the area.
When I asked the other owner, he said he is measuring from that lower part to the left. When I asked a chassis guy about this he said no. Anyway, here was the measurement from that lower area.
My next step was to try and get the car to 4" from that spot to see what that looks like. This is where the real frustration started to set in. I cant get both sides to measure the same. I need to make a video about this, but basically the car is very stiff which is expected. If I raise one side it will pick up the other side as well. So I just go back and forth and cant get them to both be the same. That then means, now I cant trust that measuring point IMO. Anyway, here is what it looked like when I had that point at 4" on that side.
Looks lower than the driver side did before I raised it up, but we are going to ignore that for now. The other thing, its all still bound up like that.
Now lets talk rear suspension. For ***** and giggles I took the coil overs from the front of the car and put them in the rear. I am not using these at all anywhere on this car, but I was tired of the square tubing. For anyone wondering, this is how they align with the offset lower mount when its hanging straight down from the top mount.
Here they are in
This is what the car sat like with the coilover in the rear, and nothing in the front. Like I said, I think the other side looks lower when I raised it up?
Yesterday I went back out to mess around some more and check the fitment of some new parts, but the lift wouldn't lower (rear locks not releasing) and that was enough to send me back inside. I need to get to the point where I can actually make progress on this thing. Anytime I start looking at it or messing with it I get immediately frustrated. Mainly because everything I NEED to do is stuff that I already paid to have done.
Old Dec 8, 2025 | 10:10 AM
  #143
Black_Sunshine_99's Avatar
F@$king hell man, I'm sorry you have to deal with this.
Maybe get on Yellow Bullet and ask some of the folks on there, some of those gents are hard core racers who might be able to help.
I hope you're considering legal action against J&E; you should only be paying for the work that was done correctly.
Old Dec 8, 2025 | 10:37 AM
  #144
Broke EF's Avatar
I have a build thread on YB, but I might make a post in some other areas. I have talked to a lot of other chassis shops and racers trying to sort this stuff out already, and they have been a big help.
I have considered it, but I probably wont. Its likely not worth the stress and the money. Just chalk it up to bad luck, and move on I guess. I hate that it means they just "get away with it" but here we are, sucks.
Old Dec 15, 2025 | 09:46 AM
  #145
Broke EF's Avatar
Friday I went out to my first PRI, which was a great time! I met a lot of people, and had some great conversations, and it got me fired up about the car some. So Saturday I wandered out to the garage and messed around some. Lets start off with the big one, installing my CJRC DZUS tool LOL
I also put in the black allen DZUS buttons I got from them as well. Besides being black, these are flat under the head rather than tapered like what was in the seat. The holes are almost too big now, but I was already considering re-doing the seat anyway, so juts throw that on the list.
Next up I wanted to start messing around with the new headers. I started on the passenger side first.
Should be enough room for an alternator over here.
Next up was the driver side
Sunday I went back out there and pulled the turbo and the crossover off the car to get a better look at what I was working with.
First problem is the steering shaft of course.
I was planning on running these in the up and forward configuration, but that is a no-go on an f-body apparently. I prefer them down and forward, how they are on the car, but that presents some issues. One being the steering shaft for sure. I might have to remount the steering rack on the k-member to lay down that u-joint some. Regardless I will have to add an intermediate shaft. The other concern is front drive components. I need an alternator, and a fuel pump at a minimum, possibly also some oiling components. I am pretty sure Bob over at AEI-CNC can get that squared away, regardless of whatever components I need to get mounted. Just slightly more of a pain in the *** than normal.
I did also spend some time looking at suspension and ride height again, but nothing new there. I was also getting some ideas and a parts list for things like the brake lines, fire system etc. Should be ordering some of those materials soon, and try and make some progress on this thing.
Old Dec 15, 2025 | 10:40 AM
  #146
Looking good boss.
Maybe have that one tube in the way of the shaft re-worked to go down out of the way and back to the collector?
Old Jan 5, 2026 | 11:42 AM
  #147
Broke EF's Avatar
I finally pulled the trigger and started ordering some material and tools for this pile. I decided to start with hardline, so brakes and fire system. I am still waiting on a big order of stuff, but here is what has come in so far.
First up are stainless steel tube nuts and collars. This is for the 3/16" line for the brakes.
I got two new Rigid tubing benders. One for 3/16" and one for 1/4"
Also got a tubing straightener, and a deburring tool
Not pictured, I picked up some bottle mounts for the fire bottles, and I did get the stainless line for the brakes already. I am waiting on the bulk of stuff I ordered though, hopefully I get that in the next day or two.
Yesterday I got off my *** and went to do some arts and crafts on the car. I am considering doing the fuel cell in the back between the rear rails. I took some measurements and did some math and it would be 13.25 gallons if that configuration worked out. So I wanted to make up a mock cell to see how it all fit and if it cleared the back window.
Really hard to tell, but it does clear.
Its not perfect, but close enough. I think I can make the bottom 1/8-1/4" longer for example. I may also raise the rear piece above the bars to gain a bit more volume. The next step is for sure to get a lid and verify its fitment 100%. One thing I did not think about with the fuel cell in this location, I technically need a firewall separating it from the driver area. The downside of building a hatch back. I guess I could just do something on that bar in front of the cell and up to the window. I am not positive on the do's and don'ts for that just yet. Anyway some progress is better than nothing I guess.
Old Jan 8, 2026 | 09:09 AM
  #148
Broke EF's Avatar
The rest of my parts came in yesterday. I guess they were not that serious about needing info from me to deliver?
Anyway that is the tubing for the fire system (black coated aluminum) the tube nuts and collars for it. Various bulkhead fittings to go from hard line to flex line for the brakes, and the nuts to hold them in place. A ton of billet p-clamps for both sizes of line. Last up is some weld fittings for a fuel cell. I have -16, -12 and -10 ORB weld fittings for whatever I come up with.
I guess I get to start bending up some hardline. Wonderful.
Old Jan 8, 2026 | 09:15 AM
  #149
Could you build the gas tank to be flush with the frame then enclose it within the frame?
You might lose a little but then you may not have to seal off the entire hatch area?
Or maybe put the tank under the car, looked like you had tons of room underneath?
Old Jan 8, 2026 | 11:13 AM
  #150
Broke EF's Avatar
Yeah, I could do that but it has drawbacks. I don't really like the idea of it being under either. It just puts the weight so far back and so low. Ill come up with something, just not sure what yet
Old Feb 12, 2026 | 09:23 AM
  #151
Any updates? it's been a month, where ya at?
Old Feb 17, 2026 | 12:59 PM
  #152
Broke EF's Avatar
First off, I really appreciate you checking in. I probably need more pressure to be honest.
The update is that I haven't even looked at the car. For whatever reason(s) I just haven't been able to get my *** out there to do anything. I might just shove it in the corner and focus on my buddies Chevelle for Sick Summer this year. We dropped out on day 1 last year, and I don't want to repeat that.
Old Feb 17, 2026 | 01:18 PM
  #153
Alright, that's cool least your still alive here lmao
Old Feb 17, 2026 | 05:05 PM
  #154
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Lou's Chevelle is a cool build, what was the problem with it last year?
Your T/A will be a badass build when done. Have you picked Manna's brains at all about the steering linkage?
