Help With CR on my gen4 6.0 with LSA
2011 Chevy Caprice LSA 93 Octane and Potentially E85 down the road, BTR Red Hot Cam
But It's a PD blower and a 6.0 the car will not be a turd from a dig at all even though your car is kinda heavy.
Don’t over think it… Just run it at whatever CR it works out to and pulley down if you want more power. The tuning window will be wider with the lower compression.
Best of success with your build.
I make a peak of 4.8psi of boost and don't have any issues on Costco pump 93.
Side note, My Dad recently went with a LSA supercharger along with a BTR red hot cam and Precision triple disk converter on his 2010 Camaro SS A6. It baselined 360whp with catted headers/cai only, then made 550whp 570wtq @ 6psi on 93 octane with 17 degrees of timing. Boost was kept low due to cats. Will probably pull a degree out of it, add a flex sensor, then run it around 20 degrees on E85...maybe a little more since the boost is low.
