CX Racing turbo kit???
Old Feb 20, 2023 | 10:41 PM
RocketBird's Avatar
Default CX Racing turbo kit???
How many of you guys actually bought this CX turbo kit for your car? I want to know pros & cons & if you would purchase this kit again.
i have a budget & everything else is 4-7k dollars so i came across this kit & it seems promising to me. My goals are 650-900 hp to the wheels.
the 5.3 lm7 is being built as we speak & the bottom end will be built.
no I don’t want to do nitrous & the procharger kit is stupid high…. Like damn there more expensive then all of the power adders combined lol
#streetcar
this setup looks nice
Old Feb 21, 2023 | 06:32 AM
ddnspider's Avatar
Fitment it's always a problem with those. Contact @Huron Speed
Old Feb 21, 2023 | 07:20 AM
RocketBird's Avatar
can’t afford them right now sorry🤷🏾‍♂️ cx kit has a small issue with the driver side header, you have to take it off in order to replace spark plug other then that i heard this is a decent kit
Old Feb 21, 2023 | 09:04 AM
ddnspider's Avatar
Theyve been on a group purchase for months, it was quite cheap on the GP. Hope fitment doesn't fight you too much.
Old Feb 21, 2023 | 09:20 AM
RocketBird's Avatar
It should. I just need a standup radiator
Old Feb 21, 2023 | 09:55 AM
LS1Formulation's Avatar
I have less than $2500 into my entire Huronspeed truck manifold T4 kit. Hot side, cold side, BOV, wastegate, and 78/75 VS Racing billet turbo. That's not cheap?
Old Feb 21, 2023 | 12:05 PM
RocketBird's Avatar
damn fr? Well may I’ll reconsider, i just need to build my trans & rear end so that’s more money outta my pocket.
Old Feb 21, 2023 | 12:17 PM
ddnspider's Avatar
what rear and trans?
Old Feb 21, 2023 | 03:09 PM
RocketBird's Avatar
TH400 trans & 10 bolt 🤷🏾‍♂️
Old Feb 21, 2023 | 03:20 PM
Don't bother building your 10 bolt. Ask me how I know. Lol. If you are sub-3500 lbs., a 10 bolt behind an automatic will generally live into the upper 10's, but NOT reliably. Find a used 9" or S60. If you're never going to see the dragstrip, then you can probably run the 10 bolt for awhile. It's a ticking time bomb, just keep that in mind. I blew mine up 14 times before I finally bit the bullet and got an S60.
Old Feb 21, 2023 | 03:38 PM
Kfxguy's Avatar
I'll let you guys in on a little secret. The 10 bolt breaks constantly if you have 3.73 and up gears. 3.42's isn't AS bad, but its MUCH stronger with 2.73's or 3.08's. With boost, thats actually a good thing. Are you wondering why they break easier with numerically higher ratios? Look how small the pinion is. The higher numerically you go, the smaller it gets. Then, think about this, at any given time you might have just 1 or 1.5 teeth engaged with the ring. put 2.73's in and it'll have 2.5-3 teeth in at any given time. The larger rear ends have a bigger pinion and ring gear and have more teeth engaging when you go to numerically higher. Some, maybe even most of you have thought about this (hopefully) but I'm sure there's people that never even considered it..... fwiw
Old Feb 21, 2023 | 04:15 PM
RocketBird's Avatar
its going to be a street/track car so I’d go with the 9inch rear end, the s60 is way to much haha
Old Feb 21, 2023 | 04:17 PM
RocketBird's Avatar
never heard of this. I have 3.23s in my 10 bolt but i may not use the damn thing since it’s known to break all the time
Old Feb 21, 2023 | 04:51 PM
ddnspider's Avatar
I wouldn't build the 10 bolt either and i wouldn't swap the rear unless it's a dedicated track car. Light weight, auto, AND taller gears and it'll live just fine. Save your money and buy a better turbo kit.
Old Feb 21, 2023 | 06:30 PM
SAPPER's Avatar
My son has a listing on here now for a Moser 12 bolt and driveshaft. but shaft won't do you any good if you have a TH400. But the diff will be priced cheaper. Only thing is there are no spring perches because his was setup for coilovers.
Old Feb 22, 2023 | 08:27 AM
I've always known the larger pinion size of the lower ( numerical ) ratios in a 7.5" axle was helpful in keeping the ring and pinion alive, but I was splitting carriers in half, shearing off the cross pin in the diff, and snapping axles too, lol. Broke a number of ring and pinions as well. An M6 finds weak points real quick.
Old Feb 22, 2023 | 08:38 AM
RocketBird's Avatar
Damn lol
Old Feb 22, 2023 | 09:24 AM
weedburner's Avatar
A Stage 1 clutch won't find those weak points as quick as the Stage 3
Old Feb 22, 2023 | 09:34 AM
Black_Sunshine_99's Avatar
x2 for Huron Speed, I ran their truck manifold kit for years and it never gave me an issue and plug access was cake with truck mani's.
The CX kit torches plug wires, even if you put sleeves on them, they will still get torched.
Spend a little extra coin for the Huron Speed kit or find a used kit.
Old Feb 22, 2023 | 09:40 AM
kinglt-1's Avatar
I don't have much experience with Turbo stuff but based on all the stuff I have read on turbo truck engines over the years, I would of just ran a SBE 5.3 and spent money on a good turbo kit(huron) vs a built motor and cheap turbo kit. The former has been proven to be a potent and reliable combo to 750-800whp for years now. Not saying anything is wrong with building a motor, my comment is in regard to a budget and where the money should be spent.
