Most compression you’d run on boost
Old Dec 19, 2023 | 07:19 AM
bthomas's Avatar
Default Most compression you’d run on boost
Curious on the current trends and advances in this area. Procharger, turbo, or tvs. Been hearing lately of some builds that are higher comp than ever thought possible 10yr ago.
Old Dec 19, 2023 | 08:31 AM
kinglt-1's Avatar
Depends on fuel used. E85 allows for a lot more compression.
Old Dec 19, 2023 | 08:57 AM
Zmg00camaross's Avatar
Low compression and boost is a thing because it helps keep street car engines alive and helps use 93 octane. Race cars, big boost and good amount of compression because like stated above fuel type is a big factor and how aggressive you want to be.
Old Dec 19, 2023 | 11:08 AM
Ls1Rx-7's Avatar
You see this higher compression + boost trend due to auto manufacturers using direct injection. Ive seen alot of guys using 93 and adding some e85 as an octane booster which allows you to run more boost and compression.
Old Dec 19, 2023 | 12:07 PM
slothman's Avatar
on 93 you are going to be limited. with e85 you can run more timing and higher compression
Old Dec 19, 2023 | 04:00 PM
I’m gonna move this to FI. Those guys know all about what works and what doesn’t with bewst.
Old Dec 19, 2023 | 04:09 PM
ls3fox's Avatar
7 Second Club
My new motor is 12.5 will be on m1
Old Dec 19, 2023 | 04:58 PM
bthomas's Avatar
yeah wasn’t thinking, should’ve put it there to begin with.
Was looking more for advanced info ex… piston and chamber shapes that have been proven, and less 101 level.
 Michael S. Palmer
Old Dec 19, 2023 | 09:37 PM
C5_Pete's Avatar
I see your 12.5:1 and raise you by 1.
My engine is 13.5:1 also on M1.
Seems most street car folks are in the 9-10 range for 93. And venture into the 11 range when using E85.
Old Dec 20, 2023 | 06:37 AM
old motorhead's Avatar
What are your power goals?
Old Dec 20, 2023 | 09:29 AM
NicD's Avatar
7 Second Club
Compression is efficiency but your fuel type and octane will determine everything, ie compression is not your friend when you are octane limited.
Old Dec 20, 2023 | 10:55 AM
Forcefed86's Avatar
You don’t give enough information for an advanced answer. Application? Class limitations? What fuel do you have available? What kind of power do you want to run and on what engine combo? RPM range? Intercooler details? Etc etc…
Boost is a MUCH more efficient at making power than upping the base compression. Higher you go w base compression, the smaller your tuning window and the peakier your cylinder pressures will be.
Low compression ratio equals lower peak cylinder pressure at the same BMEP.
Ideally you'd want just enough compression to light off your turbo. Then let boost do its job.
Old Dec 20, 2023 | 01:04 PM
bthomas's Avatar
Nothing listed, because there isn’t any build going to be done. I just enjoy reading and learning about advanced stuff to see the envelope pushed.
I guess we can call this one done as I’m probably asking someone to give the farm away as far as trade secrets go.
Old Dec 20, 2023 | 01:45 PM
Forcefed86's Avatar
As with everything racing, It’s going to vary a ton. All depends on fuel used, weight/load, application, and part combo.
Old Dec 22, 2023 | 04:18 PM
NoGo's Avatar
If you do the math on compressor+intercooler and try to stay below the temperature of combustion that GM used on the stock LS's you can come up with the below curve (static compression as a function of boost). I try and stay around this if I am going to be running just pump gas.
Old Dec 22, 2023 | 07:07 PM
gsteele's Avatar
Did you do the math or did you get this from another source? I would be interested in how it was done as this makes sense given my own experience.
Old Dec 23, 2023 | 03:49 PM
gnx7's Avatar
The beauty of a turbo setup is you turn it down on the street with pump gas.... and then turn it up for the strip on e85. My 1000rwhp+ turbo motors have all been around 9.5 to 10:1 and mainly see e85. Street cars that see a little 1/4 mile and lots of 1/2 mile racing.
We run conservative timing.... never lost a head gasket. I believe in Duttweiller's tuning method... lower timing... lots of boost!
First pass ever on new 88mm turbo. baby soft launch e85. The track was just redone.... and some pebbles/rocks at the big end that kind of made the car wander. I just let it do what it wanted to do so it moved left. It has gone a lot faster
Old Dec 26, 2023 | 10:44 PM
NoGo's Avatar
Its a long, but pretty straight forward calc if you are okay with this kind of stuff.
Just do a temperature of compression from the compressor (turbo or supercharger) for the boost you are running, put that through an intercooler efficiency calc, to determine the air temp at the inlet valve. Subtract out the temperature drop for the vaporization of the fuel (gasoline), then onto another temperature of compression for the engine (based on compression ratio) and point of timing firing. Factory design point I think was around 580 deg F, and if you back solve based on static compression around this number you get the previous curve that I put up.
Old Dec 26, 2023 | 11:00 PM
gsteele's Avatar
Thanks. The Chevy Performance LSX376-B15 has a compression ratio of 9.0:1 and a recommended 15 psi limit on pump gas which matches your graph.
Old Dec 27, 2023 | 10:53 AM
Mr. Black's Avatar
Tried running 12psi in a SBE stock ring gaps LS1 with 92 octane fuel at approx 10.7:1 compression. It would not take any timing at all without showing knock. Single digits of timing. There were some bad decisions I made with the build but was having fun still at the same time. I knew the engine would fail at some point in time but I really thought it would just break a ring land or maybe crack a sleeve.
It ended up completely destroying itself after it butted the rings. I wasn't mad but definitely frustrated at the amount of secondary damage. Learned a lot from the incident.
Now have an engine that is forged, and only 9.5:1 compression with proper ring gaps on 92 octane. Timing is now 15 to 17 degrees and no knock.
It's the only fuel we have around here without buying race gas or canned E85 and that ain't happening. At the end of the day this is for a street car and not a racecar.
