Most compression you’d run on boost
I don't think I invalidated anything. Evaporative cooling takes time to pull heat from an object. There is VERY little time to do that, especially in a highly pressurized charge pipe. We have the data from Kevin Jewers dyno cell testing that more than proves this. He used methanol as his base fuel. And replaced as much as half his total fueling pre turbo. Using the methanol pre-turbo strictly to cool the charge. He was able to bring the charge temps right around mid 150's. No matter how much more he sprayed pre turbo and pulled from the rails... the charge temps did not get any lower.
That car lost a **** load of low to mid rpm torque and throttle response. Top end wide open didn't seem to change much, but the car was way less fun to drive as it was a daily driver 3 seasons of the year and put away when there was snow/ice on the roads only.
Here is a before and after sound clip video of that car...
https://youtu.be/CHEZxMGGPG8?si=iglBqLYEcSUhiRAr
I think it's worth mentioning my experience with changing compression since most of us are talking about street cars and lower compression definitely makes a difference in the fun factor due to lower throttle response and low rpm torque below where most dyno runs start. Dyno numbers don't always tell the full story, but I have real world street driving experience changing nothing but compression.
Just for the sake of clarity, do you dispute what I'm sharing from personal experience?
Have you actually changed nothing but a significant compression change and have real world experience you want to share ?
Not saying it's the case here but the internet is very good at beating up and telling people they are wrong about things they've actually done by people that haven't actually done the things they are speculating about.
In heavy industry, aircraft, space, etc... there is a whole science behind failure points that will never resonate with this crowd, but as an example: If you have five widgets on your car where a failure of that device can occur before you go WOT (and you don't know about it) and each of those widgets work 999 out of 1000 times, the odds of you having a potential engine ending event for a daily driver (5 days a week, 12 months a year) is ~100% within the first year. The probabilities get pretty bad, pretty quickly.
If you don't drive the car that much, great - all that added complexity will never catch up to you. Or, if this is a race car and you test everything before a track day, also great, it is no longer a hidden failure. There is a reason a lot of folks have some sort of anecdotal story about a friend or themselves where a hobbs switch or a meth pump took out an engine - it isn't because they were unlucky or bought a bad system, its because it doesn't take a lot of these types of devices on a regularly driven car to make a failure very probable.
Running 16 PSI in high gear here at 10.6:1 in my cammed 5.7. I saw similar results as another member on the 1st page. Before WMI I was stuck at around 10 degrees and 10 PSI or I would get knock on 93. Adding a single M10 nozzle and windshield washer fluid let me go to 16 PSI and 12 degrees with no signs of knock.
Id say if setup correctly, that a 400+cube motor at 9.5:1 *should* be a tire frying responsive monster of a street car NA. So if you are lacking power in the low and mid range, you likely have too much cam/gear/intake in it for your desired power band and weight.
Also don’t you run a procharger? They have a lazy RPM dependent boost curve makes a huge difference. Turbo guys don’t have to deal with that. If you had a smallish turbo on it, you’d gain that lost response back and likely even more… Not that prochrgers can’t be bad ****’s! But they have an extra hurtle to jump response wise. Our small tire track record is set by a small block procharged car…
If someone had that 408 at 9.5 to 1 they might be really happy with its response, but after going from 11.4 to 1 to that low compression with no other changes it was very noticeable. From a roll you had to be in the right gear/rpm to get good response where at 11.4 you may only need to be in 3rd at low rpm to get the response and break the tires loose where at 9.5 to 1 you needed to go down to 2nd in that same scenario to make sure you were in high rpms. If that makes sense...lol...it's hard to explain and I probably did a poor job of it.
Prochargers do benefit from more cubic inches, but at 1000 rwhp I find myself taking timing out in the midrange to try to get down the track. I only have a 377 at 10.6 to 1 and 20 psi now in the current car.
