Most compression you’d run on boost
When you drop the compression without changing the swept area you increase the size of 'fillable' area. The cylinder+combustion chamber is simply larger. This increase in size of the fillable area creates an additional volume that you can fill with O2. On a N/A it isn't enough additional O2 to cover the loss in cycle efficiency from the compression, but at high boost pressures, you can multiply the amount of oxygen that is crammed into that space and eventually overcome the cycle loss.
For example, going from a 10.3 to 9:1 motor you actually increase the size of the total 'fillable' area by ~1.5%. On a boosted engine you can double/triple the density of the air filling that unswept area, so you can turn that 1.5% of increase fillable area into 3% of extra oxygen at ~15 psig and 4.5% of extra oxygen at ~30 psig. At some point, this density multiplying of the unswept area overcomes the loss in thermal efficiency from the lower static compression. This usually happens between 20-30 psig because the gain/loss in compression (although not linear) is about 3% per point of compression.
This is the whole reason why I run ~8.6:1 at ~20 psig on pump gas rather than higher compression and meth. Similar power, less detonation issues.
Conversely, for a supercharged car, I suspect there are a decent amount of cars out there that may run a smidge faster dropping the static compression a little.
I remember when LME built their motor for the LS vs coyote dyno competition, they went with over 11 to 1 compression and the fuel both were using was E85 and prochargers.. The competition was based upon peak power, average power, and power per cubic inch. Things change at the very extreme ends of anything but who is running 45 psi on a street driven LS? At realistic boost levels for a street driven LS higher compression will make more power all other things equal unless octane limited.
We can speculate all day, but I've driven the same combo with only the compression ratio changed and it's a big difference for a street driven car.
The entire combo including fuel and use of vehicle all factor in so there are cases where lower compression may be the way to go. If we are talking max peak power on a 2.0 or top fuel at 45+ psi then there are definitely different use and factors to consider in those cases.
I'm sure even at 45 psi that little 2.0 with low compression isn't going to be nearly as fun driving around town as a bigger cubic inch LS at 10 to 1 or higher at half the boost level.
Good luck with your head gaskets with a street driven LS at 45 psi anyway...lol...if you want to talk about hypotheticals that aren't based on reality or real world experience then ya that can be fun, but I'd rather talk about realistic scenarios. In my mind 45 psi isn't a realistic scenario for a street driven LS so you would never need to drop your compression so low that you could run 45 psi.
Notice the guy in post #7 is running 12.5 to 1 and running 7's. He's not octane limited with methanol and seems to know what he's doing. Do we really think he would be faster with 8 to 1 compression? I also doubt the OP is considering running anything close to the 45 psi that is being speculated about here.
If you isolate it to just pump gas vs. pump gas (ignoring the whole detonation issue) it is only a 3 HP difference between a 9.5:1 at 20 psig and an 8.6:1 at 20 psig.
A 9.5:1 shift down to 8.6:1 creates about 1% more volume, and at 20 psig, 2.4% more oxygen vs a 2.8% drop in power due to lower combustion temperature. Or in other words, the difference in power between someone running 20 psig on a 9.5:1 motor vs 20 psig on an 8.6:1 motor (all pump gas) is about a 0.4%. When you introduce meth into the mix the numbers go something like:
0% meth = 3 HP difference
5% meth = 6 HP difference
10% meth = 13 HP difference
25% meth = 32 HP difference
100% meth = 127 HP difference
You only need about 5% to 10% meth for the octane boost. Any higher than that we are talking HP gains more from a fuel shift than just detonation suppression. So, if you want to keep as true to what I said as possible, a 9:5:1 at 20 psig running 5% to 10% methanol would make 6 to 13 HP more than a motor running 8.6:1 at 20 psig. I didn't think it was worth the extra trouble.
There is no way you are losing peak power with a compression ratio increase everything else equal unless you are severely octane limited and you sure as heck aren't losing power/torque in the lower rpms.
I don't feel there is anything to lose and everything to gain by running a street driven 1000 rwhp LS combination at 10 to 1 rather than 8.5 to 1. If we get into extremes of 45 psi you aren't holding head gaskets with an LS at that boost level in a streetcar anyway. So why speculate about unrealistic scenarios?
I agree his scenario isn't valid. Got to love the internet...LOL
- The "volume" or swept area has no bearing at such low boost levels and standard compression ratios, that's a MAX effort type thing that a street car will never be at
- A full point of compression is ~3% power increase, so typical 400 horsepower engine would gain 12 horsepower, 20 psi would be 28 horsepower just from compression alone with no other changes and assuming octane isn't an issue.
- Now take that 28 horsepower and add a lot more from efficiency gains and timing increases by running meth
Either way, you certainly aren't making similar power to something else at say 9.5:1 compression @ 20 psi with meth and I would even argue that you would have less detonation issues running meth vs just pump gas.
"For example, going from a 10.3 to 9:1 motor you actually increase the size of the total 'fillable' area by ~1.5%. On a boosted engine you can double/triple the density of the air filling that unswept area, so you can turn that 1.5% of increase fillable area into 3% of extra oxygen at ~15 psig and 4.5% of extra oxygen at ~30 psig. At some point, this density multiplying of the unswept area overcomes the loss in thermal efficiency from the lower static compression. This usually happens between 20-30 psig because the gain/loss in compression (although not linear) is about 3% per point of compression.
This is the whole reason why I run ~8.6:1 at ~20 psig on pump gas rather than higher compression and meth. Similar power, less detonation issues."
You aren't losing power adding compression at realistic levels for an LS engine unless you are octane limited.
Even if you consider the opinions of others and the guy in the video they are all still talking about peak power. I'm not in disagreement with the opinion that peak power numbers don't gain a huge amount with compression. Maybe you haven't heard terms like... average power, power under the curve, torque at low rpm, or throttle response? Those are the areas where higher compression will gain you the most.
I'd rather have an efficient motor with a better top end to make more power at lower boost and lower iat so I can run even more compression for an over all more enjoyable street car driving experience.
What do you think is more fun to drive... the 2.0 at 45 psi at 8.5 to 1 compression and 850 rwhp or an LS3 with 20 psi and 1000 rwhp at 10.6 to 1 compression?
The best thing to do is consider the entire combination... if you can build an efficient motor to hit the power goals you want at lower boost you can run more compression and still make more peak power with less boost while slaughtering the low compression combo out of boost at low rpm as far as torque and throttle response.
There are people with 427's at 11 to 1 compression and the best top end money can buy making 1000 rwhp with under 20 psi on e85. They are a riot with low iat and tons of response and torque. Efficiency of the motor can't be ignored. If you are super inefficient and trying to make up with it by adding more boost you also raise your iat and this is considering you don't get out of where your blower or turbo likes to be to accomplish the extra boost. Higher IAT is going to add to spark advance limitations. This is way more complicated, and his theory doesn't take all of these factors into account.
The et improvement is not just from the motor but the mph and spool time is
